  3. The region of operation of MOS transistor
  • Replies 12
  • Views 19124
PhD Student
PhD Student over 4 years ago
HI,
I am going to design analogue circuit, and I need to show the region of operation for all transistors in the circuit after running the simulation.
My issue is: I tried two methods to show the region of operation:
The first method is: from the schematic --- > View ----> Annotations -----> setup
When I wanted to change one of the listed (such as ids, gm, ron,..etc) to be region, then I could not find the region with them.
The second method is: From the ADE L------> calculator------> select OP
When I select one of the transistors in the circuit, I see the same list (ids, gm, ron,..etc) without 'region'.
Please, how can I solve this issue? I need to show region of all the transistors, but I cannot.
Regards.
    I believe most transistor models have a region operating point parameter so the most likely explanation is that the model is a subckt model and there is information in the CDF (opParamExprList) to tell…
    Andrew Beckett over 3 years ago in reply to PhD Student +1
    PhD Student said: The device is a transistor (MOSFET) as in the title of this post (The region of operation of MOS transistor). This is getting rather frustrating, since you keep failing to answer simple…
    I believe most transistor models have a region operating point parameter so the most likely explanation is that the model is a subckt model and there is information in the CDF (opParamExprList) to tell it how to access the operating point information within the subckt model for the PDK you're using. If that's the case, the available parameters are only those in the opParamExprList setting.
    A few questions:
    1. Which PDK are you using?
    2. If you go to Tools->CDF->Edit in the CIW, and give the library name and cell name of the transistor you're using, then switch to the Simulation Information tab and change the simulator to spectre does it show anything in the opParamExprList field? If so, can you copy and paste it here?
    3. From the spectre log file, can you share the Circuit inventory section which will list the types of primitive components in use and so know which models are being used?
  • PhD Student
    PhD Student over 4 years ago in reply to Andrew Beckett
    Thank you for your reply.
    Please see the attached picture.
    Thanks.
    Andrew Beckett over 4 years ago in reply to PhD Student
    Are you sure that's the primitive transistor device in the PDK? It seems rather unlikely that the simulation information would be blank for that.
    You also only answered one of my three questions (and even then I'm not convinced you really answered the question...). Diagnosing what's wrong in a vacuum is rather tricky!
  • PhD Student
    PhD Student over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    I apologize for the late response,
    1-Which PDK are you using?
    I use XFAB technology.
    2- If you go to Tools->CDF->Edit in the CIW, and give the library name and cell name of the transistor you're using, then switch to the Simulation Information tab and change the simulator to spectre does it show anything in the opParamExprList field? If so, can you copy and paste it here?
    I did as you said and it is as in the previous picture.
    3- From the spectre log file, can you share the Circuit inventory section which will list the types of primitive components in use and so know which models are being used?
    I do not know how can I do that.
    I am looking to hearing from you.
    Regards.
    OK, so 6 months later you reply and don't tell me the PDK you're using ("XFAB technology" doesn't tell me which XFAB technology you're using). You also have blanked out the library and cell so I have no means of checking what might be going on.
    You really are going to have to provide more information if you expect an answer!
  • PhD Student
    Dear Andrew,
    Thanks for the reply.
    I am a beginner at using cadence (Virtuoso) and XFAB technology, therefore I answering as I understand what you mean.
    I am using XFAB (XT018), I am not sure if this is what you want to know. I made it blank for license reasons, I don't know if this is allowed or not.
    I suggest if you can't share the device name that has the problem, you contact XFAB. It's pretty much impossible to give you assistance without more details (the process name is one thing, but only part of the information needed).
  • PhD Student
    Thanks for the reply,
    what do you mean by process name?
    I am working on XFAB technology, The Lib name is (Primlib) and the technology is 180nm (XT018 mean the technology is 180nm).
     is this what you need to know? if not please tell me.
    Regards.
    You've told me the process name (XT018); you have now told me the library name, but you've not told me the device name that you're trying to annotate the operating points for. It could be anything!
  • PhD Student
    Hi Andrew
    • Vote Up -1 Vote Down
