  3. expanding the list of the transistor operating point an...
  • Views 11277
expanding the list of the transistor operating point annotation
Senan
Senan over 4 years ago
I am using Cadence Virtuoso version 6.1.8-64 bit
When I run the DC operating point there is limited parameters that I can show on the schematic, in my case only 4 as shown in the image below. How can I can expand the list to show more parameters of the DC operating points?
Thank you in advance
Regards
    Andrew Beckett over 4 years ago +2
    You can use the addition icon at the top (green circle with a white plus) to add another row. However, the Annotate checkbox can only be checked for rows up to the maximum number of labels on the symbol…
    You can use the addition icon at the top (green circle with a white plus) to add another row. However, the Annotate checkbox can only be checked for rows up to the maximum number of labels on the symbol - if there are only four cdsParam(N) labels on the symbol, you can't annotate any more than that without adding more labels to the symbol.
    You can however have these annotated in an info balloon still. That's controllable by using Right Mouse over the Annotate column heading, and you can then turn on the Balloon column. It's not strictly necessary, because it will be checked by default anyway. Any row that is added beyond the available labels will appear with a lilac background:
    Hope that helps!
    • Vote Up +2 Vote Down
  • Senan
    Senan over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you very much for your help,
    your answer solved my issue perfectly, and as you said I could add the additional annotation parameters to the balun annotation which is also fine for me.
    Thank you once again and best regards
