  3. Can I Undo my changes after i save the schematic in Virtuoso...
  • Views 11325
Can I Undo my changes after i save the schematic in Virtuoso?
mxm14
mxm14 over 3 years ago
As per title, i want just to undo my changes, but after SHIFT+X, i cannot do it?
Is there a way to do this?
    Andrew Beckett over 3 years ago +1
    This can be done with this cdsenv setting: cdba.undo dbUndoAcrossSave boolean t You can change this interactively by using Options→Cdsenv Editor in the CIW and then searching for "undo". It has to…
    You can change this interactively by using Options→Cdsenv Editor in the CIW and then searching for "undo". It has to be done before you do the check-and-save. Note that the "check" itself will be one undo point, and the edits you do before the check will be further undo points.
