  3. Re: Force Explorer/Maestro to refresh DC operating voltages...
  • Subscribers 127
  • Views 2540
Re: Force Explorer/Maestro to refresh DC operating voltages for annotation on schematic
slim15
slim15 over 2 years ago
I am currently using ICADVM20.1-64b.500.23 and trying to have DC voltage annotation to display on my schematic after DC operating point simulation via the “Results -> Annotate -> DC Node Voltages”.
The first simulation was performed using the netlist & run within Explorer. Next, I edit the netlist at /home/slim/sandbox/sim_opamp/maestro/results/maestro/ManualTuning.0/1/sandbox_sim_opamp_1/netlist/input.scs and rerun the simulation via the command line.
Regardless of what I do, the DC voltages would not be annotated at all. This is true even if I choose to plot transient waveforms via the “Results -> Direct Plot -> Main Form”. Explorer/Maestro would update the DC annotated voltages if I have it netlist again.
Is there a function or a simple skill code that I can use to force Explorer/Maestro to refresh the DC voltages and annotate the schematic?
Su Lim
    ShawnLogan over 2 years ago
    Dear slim15,
    I believe the reason you cannot update the operating point information on the schematic nor plot transient results is that by running the simulation from the command line, you are not updating the database for Explorer/Assembler. Assembler/Explorer rely on a database - distinct from the results database - to track simulations and the results database. When you ran the command line based simulation, the database was not updated and hence Explorer/Assembler has no knowledge of the simulation you performed.
    The database location for the *.rdb files and state information is saved in the a second directory you may specify, but its default location is your current working directory. The location of this database, as well as the database for your simulation results, can be changed and the process to do so is explained in the video at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009FFlGEAW&pageName=ArticleContent
    In my experience, I am not aware of a way to update the .rdb  database manually or force it to be aware of a new simulation. I would discourage any attempt to manually edit its files as I've had many occasions where this database has become corrupt and lost the ability to access simulation results from Assembler and Explorer. In that case, I rely on ocean scripts to traverse the results directory to access data. An ocean script can access the data from your command-line simulation. It can also be accessed using the Results Browser and ViVA - but not through Assembler or Explorer to update your annotations or use Direct Plot
    Others who monitor this Forum who have far greater knowledge may have a workaround other than using an ocean script or accessing the data from ViVa using the Results Browser for you, but sadly, I do not.
    Shawn
    Andrew Beckett over 2 years ago in reply to ShawnLogan
    By re-running from the command-line, are you running via the "runSimulation" script? If so, the results should be in the same place. You may need to close the results and re-open (via Results->Select in ADE Explorer, or via the View Results menu item over the history name in ADE Assembler). You might also need to set the annotation back to default and then back to DC voltages again to clear any caching that is done to aid performance.
    However, this is not really a supported flow, so there's no guarantee that the above will work. I didn't test it (and it is not part of any routine testing we do), so caveat emptor!
