  3. How can I highlight Mosfets in subthreshold
  • Views 9881
mxm14
mxm14 over 3 years ago
I saw that you can highlight the Mosfets in triode region using Circuit Condition window
I was wandering if there is an easy way to highlight the Mosfet in subthreshold. I wanted to put as user defined condition the parameter "region" but i did not find it in the menu for the Mosfet.
Is there a way to do this?
    Did you change the cyclic field where it shows "vsource" above to the device model being used (e.g. bsim4) before trying to pick the region parameter (using the region parameter would be the right way to do this)?
  • mxm14
    mxm14 over 3 years ago in reply to Andrew Beckett
    Yes, i did it...it does not appear in the menu relative to mosfets ( i don t know how to screen this since the menu disappears..anyway in the menu i see vgs, vth and all the other parameters).
    Regards
    Andrew Beckett over 3 years ago in reply to mxm14
    Which PDK are you using? Can you annotate region on the schematic after a dc simulation, or put another way, can you retrieve it with the OP calculator function?
