  3. Equivalent Noise Charge (ENC) Calculation of a Charge Sensitive...
  • Subscribers 136
  • Views 10854
Equivalent Noise Charge (ENC) Calculation of a Charge Sensitive Amplifier in Cadence Virtuoso
Hamzarfcs2
Hamzarfcs2 over 3 years ago
I am trying to design a Charge Sensitive Amplifier(CSA) for X-Ray detection in Cadence Virtuoso. I have some confusion that how can I calculate the Equivalent Noise Charge (ENC) of my design CSA in Cadence. Can anyone here guide me about the measurement of ENC??
  • Hamzarfcs2
    Andrew Beckett over 3 years ago in reply to Hamzarfcs2
    Please read Guidelines for the Custom IC Design Forum - (especially the part which asks you not to post the same question in multiple forums, and also providing enough information such as versions used).
  • ebecheto
    ebecheto over 3 years ago
    ENC =
    ((sqrt(iinteg(  getData( "out" ?result "noise-noise" ) **2    )) * (-1) *  VAR("Qin")) / 1.6e-19 /
    (VAR("Qin") - abs(VAR("Qin")))/(2*VAR("Qin")) * ( ymax(VT("/OUT_1")) - VDC("/OUT_1") ) -
    (VAR("Qin") + abs(VAR("Qin")))/(2*VAR("Qin")) * ( VDC("/OUT_1") - ymin(VT("/OUT_1")) ) ))
    Where Qin is your injection charge.
    Let say in you analog environment you have a Design variable Qin, a time pulse tp and a current in your ipulse Iin (pulse width : tp):
    Qin=3f
    tp=500n
    Iin=Qin/tp
