  3. LVS - not compared, number of port 0 in layout
  • Views 3748
ISHITA AGGARWAL
ISHITA AGGARWAL over 3 years ago
so after making layouts, when I try to run DRC and LVS chceks, DRC runs successfully without any errors, but when i try to run LVS for the same layout, it shows an error which says "not compared" and the number of ports are shown as 0 for layout.
Can you please help me resolve this issue. Awaiting response.
Thank you.
Ishita Aggarwal
    Which LVS tool are you using? Please also share the full error.
  • ISHITA AGGARWAL
    ISHITA AGGARWAL over 3 years ago in reply to Andrew Beckett
    Sir, I am using Calibre nmLVS.
    This is the error I got.
    CELL COMPARISON RESULTS ( TOP LEVEL )
                       #           #     NOT COMPARED     #
      Error:    Different numbers of ports (see below).
      Error:    Power net missing in layout. Ground net missing in layout.
    LAYOUT CELL NAME:         ND2
    SOURCE CELL NAME:         ND2
    INITIAL NUMBERS OF OBJECTS
                    Layout    Source         Component Type
     Ports:              0         5    *
     Nets:               9         6    *
     Instances:          2         2         MN (4 pins)
                         2         2         MP (4 pins)
     Total Inst:         4         4
    NUMBERS OF OBJECTS AFTER TRANSFORMATION
     Ports:              0         5    *
     Nets:               8         5    *
     Instances:          2         0    *    MP (4 pins)
                         0         1    *    NAND2 (3 pins)
                         1         0    *    SMN2 (4 pins)
     Total Inst:         3         1
           * = Number of objects in layout different from number in source.
    Andrew Beckett over 3 years ago in reply to ISHITA AGGARWAL
    Calibre is a tool from Siemens EDA (formerly Mentor Graphics), not Cadence. As such, this is not really the best place to ask about issues with another vendor's tool - perhaps you should contact their customer support or post the question on one of their forums?
