  3. Difference between Array Via Spacing and Via Merging
  • Views 8825
saurabh96
saurabh96 over 3 years ago
Hello , can you explain what's the difference between Array Via Spacing and Via Merging in quantus?
and how i can implant Merge via for all layer = auto in GUI as if there any extraction commands for this?
    Did you try pressing the "Help" button on the form? It takes you to the chapter describing the UI fields, which then references the relevant extraction command option (e.g. -max_via_array_size and -array_vias_spacing) which you can search for in the Quantus reference to see how to do the same from a command-line run.
