  3. VAR("variable") as string
  • Subscribers 136
  • Views 4133
amac
amac over 3 years ago
I'm trying to use a design variable as a string to pass to calcVal, but it seems that VAR("variable") only produces numerical values.
Is there a workaround or a different function to do so?
    ShawnLogan over 3 years ago
    Dear amac,
    A design variable can definitely be a string. In many cases, I used a design variable to specify a process corner. Figure 1 shows an example.
    However, I believe calcVal is a function to pass values from one test to another. Perhaps there is a means to use CalcVal to pass a string, but I am not aware of a methodology that allows this,
    Shawn
    Figure 1
    ShawnLogan over 3 years ago in reply to ShawnLogan
    Figure 1
