  3. Regarding tool crash while opening a layout file.
  • Views 9075
skillEater
skillEater over 3 years ago
Hi All,
When I am trying to open a layout the tool is getting crashed.
Last time it happend I deleted the layout folder and opened after copying my backup layout folder. But now I don't have a backup.
Somebody told me the file got corrupted so we need to delete it. is there any way to make that file correct if it is true.
waiting for a positive reply.
Ganesh Doddipatla.
    Ganesh,
    Without knowing the details, it's rather hard, but I'd suggest you use oaScan to check the cellView:
    oaScan -lib libName -cell cellName -view viewName
    Depending on what it finds, you can run again with the -repair switch to repair the database.
    Make sure you're using a current IC subversion.
    The best thing is to contact customer support (create a case after logging in). You should not need to be deleting cellViews.
  • skillEater
    skillEater over 3 years ago in reply to Andrew Beckett
    Thanks Andrew.
    The solution has worked.
