  3. error about could not get adjusted path
  • Views 9540
sjwprcker
sjwprcker over 3 years ago
Hi, when I use calculator "vt" to plot transient waveform, I click on some nets, then it seems calculator lost the link to schematic, meaning I can't put those nets name to calculator by clicking.
While the CIW window shows the info as below.
Some times re-start cadence can solve the problem, but it is annoying.
Is there any solution?
BR
    Yes, you'll need to contact customer support. Without knowing more about the situation when this occurs, the versions you're using, and so on, it's going to be rather hard to debug. This does not seem to come up as a common occurrence (from a very quick search), so it needs more digging into.
