  3. QRC menu warning: *WARNING* hiEnableMenuItem: menu item...
  • Views 8647
QRC menu warning: *WARNING* hiEnableMenuItem: menu item not in the menu
matangk2
matangk2 over 3 years ago
I'm loading Quantus QRC along with cadence.
Cadence version 618.29
QRC version 212 - latest hotfix
Upon loading the QRC window I get the following warning:
Any significance? Can't find any reference online
Cheers
Matan
    Matan,
    It's a known issue with Assura and Quantus. If you don't have Assura in the path (say just PVS) then it doesn't happen. It seems pretty benign in practice. The existing CCR is 2512583, and it's not been prioritised yet. You might want to report this to support and ask for a duplicate to be filed if the warnings concern you (it seems to be some kind of timing problem where code to enable/disable certain QRC menu items is called before they've been added to the menu).
