  3. Quantus setup ~R reporting
  • Views 9302
paulinho
paulinho over 3 years ago
I'm using Virtuoso 6.1.8-64b
I used Quantus for generating the rc extracted view. using that extracted view I'm trying to generate the parasitic report. I ran a dc simulation and then went to the option Parasitics/LDE->Report (in the maestro window where I ran the simulation). But I dont seem to be getting the R data in the report.  Is there a place where I should be providing the path of the dc simulation data ?
In the below menu, when I check the enable option, in the CIW it displays as shown beneath. Also once I check the enable option, I cant click the OK button (which is then disabled)
    This happens if you've simulated over corners or set up a sweep in ADE Assembler; if you run a single simulation, it should work - what is your simulation setup in ADE?
  • paulinho
    paulinho over 3 years ago in reply to Andrew Beckett
    I was running dc (single point with no sweeps) & tran simulation using the AMS simulator. I changed it to spectre (just for the dc sim), and now it does allow to add the result set as shown below (which was not possible with the AMS results)
    But still most of the R values are showing up as NA
