  3. Behavioral model using VerilogA
  • Subscribers 136
  • Views 11367
TUKA
TUKA over 3 years ago
Hi!
I wish to build a behavioral model for a transimpedance amplifier (TIA) using verilogA.
However, I also wish to see gain peaking in my response as well, as is the case with a practical TIA.
As I am still not into circuit level implementation, I am missing out the poles and zeroes that the parasitic inductors and capacitors would contribute.
How could I use verilogA to model gain peaking in my frequency response??
Thanks!
    ShawnLogan over 3 years ago
    Dear TUKA,
    I am not sure of all the constraints you intend to include in your model (i.e., gain, number of poles/zeroes, gain flatness, etc.) nor the type of simulation you are trying to perform. Hence, my comment may not be helpful.
    However, a simple model for AC simulations whose frequency response will show a rolloff of -40 dB/decade and can include a peak in its transfer characteristic might be a second order lowpass filter. The parameters for your model might include the Q and wo frequency as a minimum. The Q will determine the amount of transfer function peaking. The transfer function for a second order lowpass filter as function of frequency, w, is well known and may be found in many references.
    The following Forum post provides a methodology for including the transfer function in a veriloga model.
    https://community.cadence.com/cadence_technology_forums/f/mixed-signal-design/48127/how-to-model-a-low-pass-filter-using-veriloga
    Shawn
  • TUKA
    TUKA over 3 years ago in reply to ShawnLogan
    Dear Shawn,
    Thank you for getting back to me.
    I have considered my TIA as a black box. I have only 3 constraints in my model :
    1. Photodiode capacitance
    2. gain of the amplifier
    3. Feedback resistance (approx. equal to transimpedance gain)
    Sure, as you suggested, I will model it using a second order Low pass filter and play around with parameters such as Q and wo to see a peaking in the gain.
    However, I found that an AC simulation might not work in my case, because it only gives the voltage gain. What we expect from a TIA is the transimpedance gain (Output voltage / Input current).
    Thus, I am doing the same using xf or hb analysis -> Results -> Direct plot -> Main form -> Transimpedance -> dB20.
    I am getting a flat curve, and the rolloff of -20 dB/decade at the dominant pole. Now, I believe a second order LPF might provide another -20 dB/decade rolloff.
    Thanks once again for your helpful feedback!
    Andrew Beckett over 3 years ago in reply to TUKA
    One small (maybe rather pedantic) point. An AC analysis doesn't actually give you gain (voltage or current gain); you apply a small-signal input (which can be a voltage or a current), and then you can observe the signal at any node in the circuit (or any branch current) which arises from that input - assuming that you are simulating the small-signal linearisation of the circuit.
    Commonly people apply a 1V input, and then the output in volts is indeed the voltage gain as you've normalised the signal levels. You could equally apply a 1A AC current input and then the output voltage you observe would be the transimpedance.
    However, an xf analysis is more direct and is really computing a gain.
    hb would only be important if you're trying to look at nonlinearities in the circuit; if it's linear, then hb will just be a slower way to simulate it (not much for a behavioural circuit though).
  • TUKA
    TUKA over 3 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for giving me proper insights about the different type of simulations- AC, xf and hb.
    I will do an AC simulation and check by applying 1A current input and see the output voltage, which would be my transimpedance gain.
