  3. What's the Usage of Spectre Option [+escchars] and [-env...
  • Subscribers 136
  • Views 3544
What's the Usage of Spectre Option [+escchars] and [-env ade]
Smileline
Smileline over 3 years ago
Hi all!
When I click "Run" button in ADE, it generates a file called "runSimulation" under its running directory.
Its content:
{ spectre input.scs +escchars +log ../psf/spectre.out -format psfxl -raw ../psf +aps +lqtimeout 900 -maxw 5 -maxn 5 -env ade }
This command is also the real running command, which I have checked in spectre.out.
My Question is:
What's the Usage of Spectre Option [+escchars] and [-env  ade] ?
I don't find them in both spectre manual and { spectre -help }.
Thanks!
    I couldn't find a definite answer - I know they are something to do with ensuring naming is consistent in the result data for various purposes, but precisely what they do I'm not sure. This would need a question to R&D to find the details - please contact customer support to ask this (submit a case via http://support.cadence.com )
    Andrew Beckett over 3 years ago in reply to Andrew Beckett
    We now have an article on this. See When running Spectre simulation from ADE, why is '-env ade' added on the command-line Spectre call?
