  3. Bode Plot stability analysis for nonminimum phase syste...
  • Subscribers 136
  • Views 12448
Bode Plot stability analysis for nonminimum phase systems
ronaldomponte
ronaldomponte over 3 years ago
Hi everyone,
It is well known that assessing the stability of a nonminimum phase feedback system (e.g., circuits with RHP zeros and time delays) may fail using the frequency analysis of the Bode plot. That's why many textbooks instead recommend the Nyquist test.
However, there is no Nyquist test available in Cadence.
Does this mean that the STB analysis from Cadence is insufficient to evaluate my circuit's relative stability?
I very much appreciate your taking the time to answer my question.
TRANSLATE with x
English
Arabic Hebrew Polish
Bulgarian Hindi Portuguese
Catalan Hmong Daw Romanian
Chinese Simplified Hungarian Russian
Chinese Traditional Indonesian Slovak
Czech Italian Slovenian
Danish Japanese Spanish
Dutch Klingon Swedish
English Korean Thai
Estonian Latvian Turkish
Finnish Lithuanian Ukrainian
French Malay Urdu
German Maltese Vietnamese
Greek Norwegian Welsh
Haitian Creole Persian
TRANSLATE with
COPY THE URL BELOW
Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago +1
    You can access the (negative) loop gain with getData( "loopGain" ?result "stb" ) and you can for example plot it in a polar chart (see https://designers-guide.org/forum/YaBB.pl?num=1124688329 for the sign…
    Andrew Beckett over 3 years ago +1
    If you go to the results browser, you can plot the loopGain (from the stb analysis results) on a polar plot, which will then give you a Nyquist plot. You can then look at the Nyquist criterion that way…
  • Frank Wiedmann
    You can access the (negative) loop gain with getData( "loopGain" ?result "stb" ) and you can for example plot it in a polar chart (see https://designers-guide.org/forum/YaBB.pl?num=1124688329 for the sign convention issue; make sure if you need to look for encirclements of -1 or of +1).
    If you go to the results browser, you can plot the loopGain (from the stb analysis results) on a polar plot, which will then give you a Nyquist plot. You can then look at the Nyquist criterion that way (including the angle at which it crosses the unit circle and the magnitude at which it crosses the x-axis - you can use the trace info assistant to show the gamma in dB to see that as you move along the trace). Is that what you want?
  • ronaldomponte
    ronaldomponte over 3 years ago in reply to Andrew Beckett
    Yes, that's it. Thank you very much for your time on this matter, Andrew.
  • ronaldomponte
    ronaldomponte over 3 years ago in reply to Frank Wiedmann
    Many thanks, Frank.
    TRANSLATE with x
    English
    English Korean Thai
    French Malay Urdu
    TRANSLATE with
    COPY THE URL BELOW
    Back
    Back
