  3. Failed to open the GUI of Cadence Abstract Generator
  • Views 8977
Hongming Lyu
Hongming Lyu over 3 years ago
 When I started the Cadence Abstract Generator by typing `abstract` or `abstract &` in the terminal shell, the terminal failed to start graphic user interface.
Can you give some suggestions over this case? Or provide reference manual and user guide so that I can finish my project by only using SKILL script.
the feedback of the terminal shell looks like below
$ abstract
License checked out successfully...
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.01s.
$ abstract &
[1] 18425
[xinyue.gu@bicml TEMPLATE]$ License checked out successfully...
INFO (DB-120008): oaSocket connection timeout value was set to 2 seconds.
  • Alex Soyer
    Alex Soyer over 3 years ago
    Hello Hongming Lyu,
    I have exactly the same message as you but I've got the gui opened.
    Are you sure you setenv DISPLAY is correct ?
    Have tried to run another to run another GUI like nedit for example ?
    Alex
  • Alex Soyer
    Hello Hongming Lyu,
    Alex
