  3. Adexl - interactive history does not display design var...
  • Views 1912
Adexl - interactive history does not display design variables
firebolt
firebolt over 3 years ago
In interactive history, is there a way to view design variables like global ones? Right now, I check input.scs for design variables. It's good if we can have this feature to check from history list.
    Andrew Beckett over 3 years ago +1
    There's an enhancement Cadence Change Request (CCR) 1673651 asking for this, but it's not been implemented yet. As a workaround, you could use Window->Assistants->Setup DB Viewer (which is normally used…
    There's an enhancement Cadence Change Request (CCR) 1673651 asking for this, but it's not been implemented yet. As a workaround, you could use Window->Assistants->Setup DB Viewer (which is normally used for debug purposes). You first need to do "View Results" on the history in the History tab of the Data View assistant, then you can expand the history, then history name, then checkpoint, then tests, then the test name you want, and then vars - and you can see them all. It's not very nicely presented though, since it's intended for debug more than anything (as I said).
  • firebolt
    firebolt over 3 years ago in reply to Andrew Beckett
    This will help as a workaround. Hope CCR will be implemented soon. Thanks Andrew.
