  3. Behavioral modelling using verilogA for a TIA
  • Subscribers 136
  • Views 9997
TUKA
TUKA over 3 years ago
Hi folks!
I am working on the behavioral model of a Transimpedance amplifier (TIA) using verilogA. As I am new to the world of behavioral modelling, I wish to get some questions clarified right away:
1) As we have several different topologies for designing a TIA (such as Common gate, common source with resistive feedback, Regulated Cascode, Darlington pair etc.), do I have to write a verilogA code for each topology or should the code be generic irrespective of the topology?
2) In my model, does it make sense to consider transistor/operating point dependent attributes (such as gm, beta, un.Cox, W/L ratios etc.) as real parameters if these appear in my design equations?
3) As input referred noise current is a critical parameter for a TIA, I wish to include that in my model as well. Any leads towards that would be helpful.  Also, in case of a TIA, how do I account for shot noise and flicker noise in the behavioral model ?
Thanks!
    ShawnLogan over 3 years ago
    Dear TUKA,
    There is no "right" answer to either of these questions. You need to decide what level of modeling you are trying to achieve and consider the time required to generalize a model while maintaining model accuracy.
    Ken Kundert has written extensively on means to include colored noise sources in a verilogA base model. A couple of references regarding shot noise and flicker noise respectively follow. Please do not assume these two will cover all of your noise modulation needs, but these are just two examples.
    https://designers-guide.org/forum/YaBB.pl?action=print;num=1466763115
    Flicker Noise Formulations in Compact Models - Ken Kunderthttps://kenkundert.com › docs › tcad20-flicker-no...
    Shawn
    Dear TUAK,
    I replied but it was flagged as spam. Hopefully, it will be reviewed and considered worthy of a response.
    Shawn
  • TUKA
    TUKA over 3 years ago in reply to ShawnLogan
    Dear Shawn,
    Thank you for your response to my questions,and thanks for sharing me the reference to the coloured noise model.
