  3. Adexl - max jobs not exceeding limit 100
  • Views 6398
firebolt
firebolt over 3 years ago
I saved a job policy with max jobs 1000 and defined same in cdsinit. When simulation is fired and I check individual test job setup, it gets reverted to 100 but no change in command. I verified in bjobs list. I see 100 running jobs only and nothing in pending. And in adexl interactive, I see rest 50 in pending state because they are not submitted to farm yet by adexl (I think). Confirmed with local CAD guy, no limit on number of spectre/bjob licenses (probably not 100). Please help here.
envSetVal("adexl.icrpStartup" "defaultJobPolicy" 'string "bsub44")
    Andrew Beckett over 3 years ago +2
    A few points: You should be using ADE Assembler rather than the obsolete ADE XL ADE remembers the last job policy used in that ADE XL/maestro view and that's what will be shown next time, even if…
    Andrew Beckett over 3 years ago in reply to firebolt +1
    You said that you're using maestro only, yet the earlier screenshot was from ADE XL. LSCS is the newer job submission implementation which is designed for greater scalability and has lightweight processes…
    Are you using a non-Cadence simulator? I can't think of any reason why it would switch back other than that (in current releases LSCS is not supported for third-party simulators), or maybe there's some…
    A few points:
    1. You should be using ADE Assembler rather than the obsolete ADE XL
    2. ADE remembers the last job policy used in that ADE XL/maestro view and that's what will be shown next time, even if you change the default (the default is for new views).
    3. You appear to be using the per-test job policy settings (Right Mouse over the test name in the Data View assistant, then pick Job Setup). You only really should use that if you really need to override it per-test, otherwise you'd use the setting for all tests using the Options->Job Setup menu in ADE. Again, the per-test job setup will be retained if set
    4. 1000 jobs is likely to strain the ADE infrastructure with ICRP; you should switch to ADE Assembler and use LSCS if you want to run this number of jobs in parallel.
    • Vote Up +2 Vote Down
  • firebolt
    firebolt over 3 years ago in reply to Andrew Beckett
    Yes, I am using Maestro only. Even with global job setup, say max jobs 300, still I see jobs limited to 100. Let me check with LSCS. What's the difference between LSCS & ICRP?
    envSetVal("maestro.lscs" "defaultSimulationJobPolicy" 'string "bsub44")
    LSCS is the newer job submission implementation which is designed for greater scalability and has lightweight processes for the various steps rather than invoking a whole virtuoso which consumes resources (particularly memory) for long periods of time whilst simulations are running.
    Your new screenshot shows the number of jobs being 300, so if you're having an issue with it being limited, by far the best solution would be to contact customer support. That's what it's for...
  • firebolt
    I fired sims on LSCS. Simulations are running. But when I check job setup again, it is switched back to ICRP. What I am missing here?
    Are you using a non-Cadence simulator? I can't think of any reason why it would switch back other than that (in current releases LSCS is not supported for third-party simulators), or maybe there's some customisation in your environment overriding job policies.
    Please contact customer support, as I said before.
  • firebolt
    Thanks Andrew for your reply. I will check my settings.
