  3. Maestro - customizing default ouptut save options
  • Subscribers 136
  • Views 6274
firebolt
firebolt over 3 years ago
In general, I save only selected voltages & currents, and no other information to save disk space & time. For any new test, I have to customize settings again (from allpub). Is there a way to make them default?
    ShawnLogan over 3 years ago +2
    Dear firebolt, I think this might accomplish what you want firebolt. There is a troubleshooting article at URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007Mmz9UAC&pageName…
    Andrew Beckett over 3 years ago in reply to ShawnLogan +2
    Shawn, That's not really the best way to set defaults for new views though - it's much simpler to do with cdsenv settings: spectre.outputs save string "selected" spectre.outputs primitivesInfo boolean…
    Andrew Beckett over 3 years ago in reply to firebolt +1
    I would expect there would be similar cdsenv settings for a third-party simulator, but of course they will be specific to that simulator. You should ask the vendor/provider of that integration for details…
    Dear firebolt,
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007Mmz9UAC&pageName=ArticleContent&oMenu=People%20who%20viewed%20this%20also%20viewed
    that contains a set of SKILL statements at the end of it to include in your .csdinit file. The code contains a set of defaults you can either create and save or include the .cdsinit statements. The SKILL command of interest is
    asiSetKeepOptionVal()
    and is documented in the SKILL reference manual (part 1) at URL:
    https://support.cadence.com/apex/techpubDocViewerPage?xmlName=skartistref.xml&title=Virtuoso%20ADE%20SKILL%20Reference%20-%20Part%20I%20--%20Keep%20Option%20Functions%20-%20asiSetKeepOptionVal&hash=pgfId-1032956&c_version=ICADVM20.1&path=skartistref/skartistrefICADVM20.1/chap12.html#pgfId-1032956
    I hope this is what you were hoping to find!
    Shawn
    • Vote Up +2 Vote Down
    Shawn,
    spectre.outputs primitivesInfo boolean t
    spectre.outputs modelParamInfo boolean t
    spectre.outputs subcktsInfo boolean t
    spectre.outputs elementInfo boolean t
    spectre.outputs assertsInfo boolean nil
    spectre.outputs designParamValInfo boolean t
    spectre.outputs outputParamInfo boolean t
    spectre.outputs allcapInfo boolean nil
    spectre.outputs extremesInfo boolean nil
    You can set these to nil or t (for the "Info" analyses). This is the .cdsenv syntax, and for an entry in the .cdsinit it would be:
    envSetVal("spectre.outputs" "elementInfo" 'boolean nil)
    for example. Or:
    envSetVal("spectre.outputs" "save" 'string  "selected")
  • firebolt
    firebolt over 3 years ago in reply to Andrew Beckett
    Thanks Andrew & Shawn. Works for spectre simulator. Does it support for third-party simulator? I tried, its not working.
    I would expect there would be similar cdsenv settings for a third-party simulator, but of course they will be specific to that simulator. You should ask the vendor/provider of that integration for details as to how to set the defaults in their integration (in general this should be controlled by cdsenv settings, but I can't tell you what they are called in an unnamed (or even a named) third-party integration).
  • firebolt
    I will check with them. Thanks.
