  3. How to edit scs files. I want to add this equation ueff...
  • Views 1899
How to edit scs files. I want to add this equation ueff=u0*(sigma*pi)to the ne. scs file in bsim3v3
hahaismyfriend
hahaismyfriend over 3 years ago
    Use a text editor?
    Seriously, I have no idea what "the ne .scs file in bsim3v3" is. I assume you have some existing model file called ne.scs for your technology - if you want to modify it, then you can of course take a copy of that file, edit it, and then use Setup->Model Libraries to point at the modified file (if you're using ADE).
    Your question is so lacking in context that it's hard to give any concrete advice.
