  3. Wrong keyboard mapping
  • Subscribers 137
  • Views 11866
Kurt63
Kurt63 over 3 years ago
when we use Virtuoso (Library Manager IC6.1.8) running on a Linux server from a Solaris 10 box, the key mapping is wrong (e.g. q -> r, w -> p, e -> 6).
Our command to perform the connection is 'ssh -X server', what works well for all other programs.
From a PC with an X emulator (MobaXterm, X2Go)  also Virtuoso is okay.
What can I do to solve this problem?
Kay
  • Kurt63
    Addition: I found with 'xmodmap -pke', that keycode '27' from the Sun Type 6 keyboard is interpreted as 'Q' while it from the PC keyboard results in an 'R'.
    Apparently Virtuoso interprets the keycodes as they are originated in a PC keyboard.
    Unfortunately 'setxkbmap' leads to 'XKB extension not present on localhost:10.0' (Xsun / X11R6.6.2). But remember - all other applications are okay.
    Regards
    Kay
    Andrew Beckett over 3 years ago in reply to Kurt63
    Kay,
    No idea, I'm afraid, but what you're doing is pretty unusual (I'm not aware of anyone using Solaris boxes for such things nowadays). The fact that xmodmap shows the wrong key assigned is a little strange. You could also try using "xev" and seeing what that shows as the key that is pressed when you hit the keys on the keyboard. If that mapping is wrong, then all bets are off.
    I don't know which window manager you're using - presumably that's a Window manager on the Sun (CDE?), but normally you can control the keyboard layout in (say) KDE via the System Settings->Input Devices->Keyboard. Not sure how that's going to work in the case when it's wrongly mapping the keys - or how some applications "are okay". Without seeing the system and what's going on, it's hard to debug, and I wouldn't know where to find anyone with this set up.
  • Kurt63
    Kurt63 over 3 years ago in reply to Andrew Beckett
    thank you very much for your answer.
    Actually CDE 1.6.10 is the Window manager on the Sun. 'xev' (executed on the linux server via ssh from the solaris box) delivers the correct keycode and key.
    To enable the XKB extension, I appended '+kb' to '/usr/dt/config/Xservers'. And indeed I'm one step further (on the Solaris box via 'ssh -X' to the Linux server):
    $ setxkbmap -v 10 -rules /usr/share/X11/xkb/rules/base -model sun_type6_usb -layout us
    Setting verbose level to 10
    locale is C
    Warning! Multiple definitions of rules file
             Using command line, ignoring X server
    Warning! Multiple definitions of keyboard model
    Warning! Multiple definitions of keyboard layout
    Trying to load rules file /usr/share/X11/xkb/rules/base...
    Success.
    Applied rules from /usr/share/X11/xkb/rules/base:
    rules:      /usr/share/X11/xkb/rules/base
    model:      sun_type6_usb
    layout:     us
    Trying to build keymap using the following components:
    keycodes:   sun(type6_usb)+aliases(qwerty)
    types:      complete
    compat:     complete
    symbols:    pc+sun_vndr/us+sun_vndr/solaris(defaults)
    geometry:   sun(type6)
    Error loading new keyboard description
    $ setxkbmap -rules /usr/share/X11/xkb/rules/base -query
    model:      type6_usb
    layout:     us
    It seems to exist a problem with loading the new keyboard layout. But the main trouble is now, that Virtuoso completely fails:
    Qt Warning: Qt: couldn't get core keyboard device info
    \w Qt Warning: The X11 connection broke: No error (code 0)
    IO Error 11 (Resource temporarily unavailable) on Display "localhost:11.0" at UTC 2023.02.06 13:23:25.999
    \e IO Error 11 (Resource temporarily unavailable) on Display "localhost:11.0" at UTC 2023.02.06 13:23:25.999
    Aborting due to fatal X IO error.
    Other (also) QT Applications are still running without a hitch.
    Kind regards
    Kay
  • Kurt63
    Ain't got a solution as yet but probaly the reason for this strange behavior.
    After some investigation I found out, that
    1. The XKEYBOARD extension (XKB) of Solaris 10 isn't fully functional. Therefore QT (starting with version 5) falls back to the hard coded keyboard, what I can overwrite with the five variables XKB_DEFAULT_RULES, XKB_DEFAULT_MODEL, XKB_DEFAULT_LAYOUT, XKB_DEFAULT_VARIANT and XKB_DEFAULT_OPTIONS.
    2. This mechanism seems to be buggy in QT 5.9.1 (used in IC_6.1.8.060). Because a fix is implemented in QT 5.11.0, we have to wait the the appropiate IC release.
    Kind regards,
    Kay
