  3. spectre: save all currents connected to a given node, but...
  • Subscribers 136
  • Views 10778
spectre: save all currents connected to a given node, but exclude given connections
Zol
Zol over 3 years ago
Spectre has an option to save all terminal currents connected to a node. Below is an example code:
save my_node:currents probelvl=2
Is there any way to exclude some terminals, like the bulk of the transistors or the supplies of digital cells (I can match a pattern to the terminal names)? I tried
save my_node:currents probelvl=2 exclude=[*:b *:inheretedSupplyName]
But it does not work. Removing these would save disk space and I also hope that it would save up the simulations.
    ShawnLogan over 3 years ago
    Dear Zol,
    From my understanding,  by default, the save statement in spectre uses the terminal name for element currents and the terminal index for subcircuit terminals. Assuming your transistors are implemented as subcircuits, the save statement will use its terminal number and not its name. I think you can check this by examining your input.scs file. This might explain why your attempt to exclude the bulk node terminal currents using the syntax "*:b" is not excluding the bulk node currents. You can change the default behavior to use the terminal name by setting the option useterms=name. I just searched the site, and there is a Troubleshooting article at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    that relates to this issue that may be helpful if you did not find it in your search.
    Shawn
  • Zol
    Zol over 3 years ago in reply to ShawnLogan
    Thanks for the reply. I set useterms=name through ADE's Environment Windows. I confirmed it in the netlist. I am saving only selected currents. I have only one save statement for the currents, and I still see the bulk currents. I have not seen any mention about the save statements in spectre.out. I have this problem with baseline spectre and with APS as well.
    Can you think of anything else, what I should set to make it work?
    I use IC 6.1.8-64b.500.13.EHF7868 with spectre 20.1.0.348.isr10 64bit
    Andrew Beckett over 3 years ago in reply to Zol
    I tried with the latest Spectre (21.1.0.664.isr16) and it doesn't seem to be possible as far as I can see.
    You should contact customer support.
