  3. Behavioral model for a VGA
  • Subscribers 136
  • Views 10163
TUKA
TUKA over 3 years ago
Hello all,
I have modelled a Transimpedance amplifier (TIA) using verilogA as a second order low pass filter so that I could observe the effect of gain peaking (by tuning the Q factor). Now, in order to flatten the TIA response, I would like to cascade my TIA with a variable gain amplifier (VGA).
My existing TIA has a bandwidth of around 50 GHz and a gain of around 60 dBohm.
I am interested in building a behavioral model for a VGA, just similar to a TIA using verilogA. My main focus is to flatten the TIA frequency response using the VGA response.
Also, I would be interested to know how could I improve the bandwidth of the existing TIA using any suitable behavioral model.
Any leads towards this would be great!
Thanks!!
    ShawnLogan over 3 years ago
    Dear TUKA,
    Please allow me to add a pedantic note to your request. A variable gain amplifier (VGA) is usually designed as a broadband amplifier without any intentional frequency compensation for prior stages or the response of a communications channel. If you are trying to equalize the response of the TIA, you might consider using some type of linear equalizer followed by a VGA.
    It is not clear to me what parameters you are trying to include in your model. Hence, I can only provide a reference that includes an example listing for a low-noise amplifier with options for its IP3 and noise figure at URL:
    https://designers-guide.org/modeling/modeling-rf-systems.pdf
    If you have already created your TIA model, from my simplistic understanding, it seems as if you can use it as a template for a compensating linear equalizer with the inverse frequency response.
    Shawn
  • TUKA
    TUKA over 3 years ago in reply to ShawnLogan
    Hi Shawn,
    Thank you for getting back to me, and thanks for providing me the right insights.
    I am trying to include the following parameters in my model:
    1. Gain range (for example -10 dB to +20 dB)   2. Bandwidth (around 50 to 60 GHz)   3. Noise figure    4. Linear-in-dB response
    Thank you!
    ShawnLogan over 3 years ago in reply to TUKA
    Dear TUKA,
    This is helpful to me. I think the code shown in Listing 1 of the reference I included by Ms. Jesse Chan might serve as a very good starting point for your model. Its parameters, from the reference, are shown as Figure 1.
    Good luck TUKA!
    Shawn
    Figure 1
    from listing 1 of URL: designers-guide.org/.../modeling-rf-systems.pdf
  • TUKA
    Dear Shawn,
    Thanks a lot for sharing the reference document.
