  3. define variable in scs file
  • Views 10362
sjwprcker
sjwprcker over 3 years ago
I would like to create a .scs file, which will be included as a normal model file.
The content is
section AAA
parameters
+ X=0
+ Y=0
+ Z=0
endsection
X,Y,Z are variable to be defined. I wish their function the same as the variable defined in corner setup.
The sim always fail. It seems the syntax is wrong.
I am wondering what is the standard format to define my own .scs file?
my cadence version is IC618.500.24. Specter version is 21.1.0.460.isr10.
    It does tend to help if you actually share the error. Otherwise how are we supposed to know what was wrong?
    Normally (by convention) any file containing sections would also have library/endlibrary around it; however, this is not compulsory.
    I used your file, and included it with:
    include "sectiononly.scs" section=AAA
    and it works with no problem. If you had tried to include it without specifying the section, it will fail with:
    Error found by spectre during circuit read-in.
        ERROR (SFE-874): "sectiononly.scs" 2: Cannot run the simulation because syntax error `Unexpected keyword "section"' was encountered at line 2, column 0. Correct the syntax error and rerun the simulation.
        ERROR (SFE-874): "sectiononly.scs" 12: Cannot run the simulation because syntax error `Unexpected end of section "endsection"' was encountered at line 12, column 0. Correct the syntax error and rerun the simulation.
    If you don't want to have to specify a section at the time you include the file, simply omit the section AAA and endsection lines from your file. The whole point of sections is that you can have multiple alternative sections within a file and choose which to include by using the section parameter of the include statement.
