  3. modify PCell parameter due to skill code
  • Replies 8
  • Views 12259
AutoJeff
AutoJeff over 3 years ago
Hi all,
I want to modify some parameters of PCell due to skill code. the code is in the following:
procedure(modifyCDFParam()
   let((cv cvSch cdfData)
   cv=geGetEditCellView()
  cvSch=dbOpenCellViewByType(cv~>libName cv~>cellName "schematic" "schematic")
  foreach(inst cvSch~>instances
   cdf=cdfGetInstCDF(inst)
   vfoSetParam(cdfData "sdMtlWidth" "280n")
  vfoSetParam(cdfData "leftTap" nil)
when I load the code and run the the function modifyCDFParam(), the code don't work and show the error: *Error* putprop: first arg must be either symbol, list, defstruct or user type - nil.
does anyone help to debug what is the problem of the code?
thanks
    Two issues:
    1. You're getting the CDF for the instance in the variable cdf and the vfoSetParam is using a different variable cdfData
    2. You probably should check that cdf is non-nil (or even the right kind of component) before trying to set parameters. After all, using ~>instances will get all the pins and global taps etc as well as any devices in your schematic.
  • AutoJeff
    AutoJeff over 3 years ago in reply to Andrew Beckett
    I'm not clear for this. could you please help modify the code for me?
    thank you very much
  • AutoJeff
    AutoJeff over 3 years ago in reply to AutoJeff
    I miss something. the cdf should be cdfData.
    thanks
    Andrew Beckett over 3 years ago in reply to AutoJeff
    cdfData=cdfGetInstCDF(inst)
    when(cdfData
  • AutoJeff
    thank you very much. it does work now.
    Jeff
  • AutoJeff
    I write a code in the following to modify the cells in a library. the code works in process a, but it doesn't work in process b. I found an interesting thing: I run the code first, it will moidfy one instance parameter; it will modify the next instance parameter when I run the code twice.
    my code:
        if (inst~>libName==techGetTechFile(cvSch)~>libName
        then
        when(cdf~>sdMtlWidth  vfoSetParam(cdf "" "280n"))
        when(cdf~>leftTap  vfoSetParam(cdf "leftTap" nil))
    when I run the code, the ciw report the error:
    *** Error in routine putprop:
    Message:*Error* putprop: first arg must be either symbol, list, defstruct or user type
    Entering new debug toplevel due to error:
  • AutoJeff
    sorry, the "" should be "sdMtlWidth"
  • AutoJeff
    the whole code:
        then
       printf("Proceeding the instance: %s\n" inst~>name)
        when(cdf~>sdMtlWidth  vfoSetParam(cdf "sdMtlWidth " "280n"))
