  3. transient noise start time
  • Views 9904
sjwprcker
sjwprcker over 3 years ago
I am try to activate transient noise, not from beginning, but from a specific time, e.g., t0.
Is there any way to define such a function?
My cds is IC618.500.24, and spectre version is 21.1.0.460.isr10.
Thanks a lot!
    Andrew Beckett over 3 years ago +2
    Turn on transient noise, and also the dynamic parameter checkbox for the transient analysis. Pick the parameter isnoisy and then define as a vector. You can then set isnoisy to no at time 0, and to yes…
    Turn on transient noise, and also the dynamic parameter checkbox for the transient analysis. Pick the parameter isnoisy and then define as a vector. You can then set isnoisy to no at time 0, and to yes at the time you want to enable it at.
    • Vote Up +2 Vote Down
  • sjwprcker
    sjwprcker over 3 years ago in reply to Andrew Beckett
    Great answer, thanks a lot, Andrew!
