  3. Is it required a particular license to plot internal VerilogA...
  • Replies 11
  • Views 16430
Is it required a particular license to plot internal VerilogA parameters?
Rawcode
Rawcode over 3 years ago
Hello everyone.
I'm trying to plot internal variables of my VerilogA model (they are defined as electrical nodes), but I'm facing some issues.
To do so I click to "Outputs->To be Saved->Select OP Parameters" and I select the VerilogA instance.
Once I'm in the Output panel, I click to the "..." button relative to the instance I've selected, but when I click to "Get from Simulation" the whole software freezes.
Reading the logs both of the license server and cds.log I notice these
-cds.log:
\o Notice from spectre during license check-out.
\o     Waiting for available license for Spectre.
-License server log:
11:37:55 (cdslmd) UNSUPPORTED: "Virtuoso_Acceler_Parallel_sc" (PORT_AT_HOST_PLUS ) REDACTED@REDACTED (No such feature exists. (-5,346:104 "Connection reset by peer"))
11:37:55 (cdslmd) UNSUPPORTED: "Virtuoso_Multi_mode_Simulation" (PORT_AT_HOST_PLUS ) REDACTED@REDACTED [APS Base 980510] (2 licenses) (No such feature exists. (-5,346:104 "Connection reset by peer"))
I also tried to plot the internal value by writing manually the variable name, but I get this error:
ERROR (WIA-1006): Unable to plot expression <OT("/I0" "phase" "REDACTED")> because it does not evaluate to an object that can be plotted, like a waveform or
parametric wave. See the Visualization & Analysis Tool documentation for information
about the types of objects that can be plotted in Visualization & Analysis Tool. Only
the expressions that evaluate to those objects can be plotted.
*Warning* Wave111 is not a waveform object that can be displayed and
will be DELETED automatically.
Now I'm wondering, is it necessary to have a particular license to perform such analyses? What am I doing wrong?
Thank you in advance.
P.S.
Here are my licenses (copied from the license file):
# Product Id  : 38500,  [Version: 21.1]
# Product Name: Spectre(R) Classic Simulator
# Licensed Rights:
#   Start Date: 11-nov-2022 Exp Date: 05-mar-2023   Product Qty: 1 Type: Floating
#   Product Comments:
#   Feature: Virtuoso_Spectre               [Version: 21.1] [Feature Qty Per Product: 1]
# Product Id  : 95100,  [Version: 6.1.8]
# Product Name: Virtuoso(R) Schematic Editor L
# Licensed Rights:
#   Product Comments:
#   Feature: 111                            [Version: 6.18] [Feature Qty Per Product: 1]
#   Feature: 940                            [Version: 6.18] [Feature Qty Per Product: 1]
#   Feature: 945                            [Version: 6.18] [Feature Qty Per Product: 1]
#   Feature: Virtuoso_Adv_Node_Framework    [Version: 20.1] [Feature Qty Per Product: 1]
#   Feature: Virtuoso_Schematic_Editor_L    [Version: 6.18] [Feature Qty Per Product: 1]
# Product Id  : 95260,  [Version: 6.1.8]
# Product Name: Virtuoso(R) ADE Assembler
# Licensed Rights:
#   Product Comments:
#   Feature: Virtuoso_ADE_Assembler         [Version: 6.18] [Feature Qty Per Product: 1]
# Product Id  : COSLITE,  [Version: 1.0]
# Product Name: COSLITE Access
# Licensed Rights:
#   Product Comments:
#   Feature: COSLITE_ACCESS                 [Version: 1.0] [Feature Qty Per Product: 1]
    Andrew Beckett over 3 years ago in reply to Andrew Beckett +1
    OK, I've reproduced the problem. It seems that pressing the "Get from simulation" button runs a small DC simulation to retrieve the available operating point parameters, and does this by using a small…
    The issue is that you only have a Spectre Classic license and not an APS license (that's what it is trying to check out), and so the simulation is not running.
    In ADE, go to Setup->High Performance Options and change the simulation mode from APS to Spectre, and then your simulation should run OK.
  • Rawcode
    Rawcode over 3 years ago in reply to Andrew Beckett
    I've already set the simulation mode from APS to Spectre. I do this every time, otherwise any kind of simulation will not run.
    Andrew Beckett over 3 years ago in reply to Rawcode
    Well, if you had already set it to use Spectre (which seems unlikely given the license log file stating that it was trying to use the APS license), then it must be because your single Spectre license is already in use.
    By the way, if you want to change the default so that new ADE sessions will pick Spectre by default, you can add this to your .cdsinit file (note, this will only impact new maestro views and ADE L states):
    envSetVal("spectre.turboOpts" "uniMode" 'string "Spectre")
  • Rawcode
    That sounds strange to me.
    I'm the only user of this workstation, how can this license be already in use?
    I suggest you try (in a terminal window) running:
    lmstat -f Virtuoso_Spectre -c $CDS_LIC_FILE
    to see what licenses are in use. If nothing is being used, please post the entire Spectre log file (use Insert->Image/Video/File and attach it as a ".txt" file).
  • Rawcode
    Hi Andrew.
    the command you suggested to run, produces the following output:
    Users of Virtuoso_Spectre:  (Total of 1 license issued;  Total of 0 licenses in use)
    Can you tell me where I can find the log file?
    When running a simulation in ADE, you normally get a popup window showing the simulation log file (it's called "spectre.out"); you mentioned earlier a line about waiting for a spectre license and that was from 'cds.log" - which seemed slightly odd (I would expect that message to appear in the spectre.out file instead). You can see the path to the log file in the banner of the popup window, but you can also use File->Save As in that window to save it to another location.
  • Rawcode
    Here is the Spectre log.
    When I press the button "Get from Simulation" the log doesn't get updated.
    Fullscreen 2703.spectre_out.txt Download
    Spectre (R) Circuit Simulator
    Version 21.1.0.546.isr13 64bit -- 4 Nov 2022
    Copyright (C) 1989-2022 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: fvlupo   Host: SeeQCNapoli   HostID: E18F5121   PID: 621879
    Memory  available: 130.3122 GB  physical: 134.8106 GB
    Linux   : AlmaLinux release 8.7 (Stone Smilodon)
    CPU Type: AMD Ryzen 9 5950X 16-Core Processor
            Socket: Processors [Frequency] (Hyperthreaded Processor)
            0:       0 [3400.0] (),  1 [3400.0] (),  2 [3400.0] (),  3 [4325.5] (),  4 [3400.0] ()
                     5 [3400.0] (),  6 [3400.0] (),  7 [3400.0] (),  8 [3400.0] (),  9 [3400.0] ()
                    10 [3400.0] (), 11 [3400.0] (), 12 [3400.0] (), 13 [3400.0] (), 14 [3400.0] ()
                    15 [3400.0] (), 16 [4333.0] (), 17 [3400.0] (), 18 [3400.0] (), 19 [3400.0] ()
                    20 [3400.0] (), 21 [3400.0] (), 22 [3400.0] (), 23 [3400.0] (), 24 [3400.0] ()
                    25 [3400.0] (), 26 [3400.0] (), 27 [3400.0] (), 28 [3400.0] (), 29 [3400.0] ()
                    30 [3400.0] (), 31 [3400.0] ()
    System load averages (1min, 5min, 15min) : 3.6 %, 1.8 %, 1.4 %
    Hyperthreading is enabled
    Simulating `input.scs' on SeeQCNapoli at 1:27:14 PM, Mon Feb 20, 2023 (process id: 621879).
    Current working directory: /home/fvlupo/simulation/SEEQC_SFQ_CIRCUITS/jtl_test/maestro/results/maestro/ExplorerRun.0/1/SEEQC_SFQ_CIRCUITS_jtl_test_1/netlist
    Command line:
        /usr/local/cadence/installs/SPECTRE211/tools.lnx86/bin/spectre -64  \
            input.scs +escchars +log ../psf/spectre.out -format psfxl -raw  \
            ../psf +lqtimeout 900 -maxw 5 -maxn 5 -env ade -ahdllibdir  \
            /home/fvlupo/simulation/SEEQC_SFQ_CIRCUITS/jtl_test/maestro/results/maestro/ExplorerRun.0/sharedData/CDS/ahdl/input.ahdlSimDB  \
            +logstatus
    Licensing Information:
    [13:27:14.072593] Configured Lic search path (21.01-s002): 5280@SeeQCNapoli
    [13:27:14.131144] Periodic Lic check successful
    Loading /usr/local/cadence/installs/SPECTRE211/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Loading /usr/local/cadence/installs/SPECTRE211/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
    Loading /usr/local/cadence/installs/SPECTRE211/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
    Loading /usr/local/cadence/installs/SPECTRE211/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
    Loading /usr/local/cadence/installs/SPECTRE211/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
    Reading file:  /home/fvlupo/simulation/SEEQC_SFQ_CIRCUITS/jtl_test/maestro/results/maestro/ExplorerRun.0/1/SEEQC_SFQ_CIRCUITS_jtl_test_1/netlist/input.scs
    Reading file:  /usr/local/cadence/installs/SPECTRE211/tools.lnx86/spectre/etc/configs/spectre.cfg
    Reading file:  /home/fvlupo/Documents/SFQ/Circuits/SEEQC_SFQ_CIRCUITS/jj_shunt/veriloga/veriloga.va
    Reading file:  /usr/local/cadence/installs/SPECTRE211/tools.lnx86/spectre/etc/ahdl/constants.vams
    Reading file:  /usr/local/cadence/installs/SPECTRE211/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading file:  /home/fvlupo/Documents/Supergate/Circuits/testLib/vgauss/veriloga/veriloga.va
    Time for NDB Parsing: CPU = 33.937 ms, elapsed = 95.799 ms.
    Time accumulated: CPU = 66.962 ms, elapsed = 95.8009 ms.
    Peak resident memory used = 148 Mbytes.
    Existing shared object for module jj_shunt is up to date.
    Installed compiled interface for jj_shunt.
    Existing shared object for module vgauss is up to date.
    Installed compiled interface for vgauss.
    Time for Elaboration: CPU = 7.285 ms, elapsed = 7.28798 ms.
    Time accumulated: CPU = 74.282 ms, elapsed = 103.124 ms.
    Peak resident memory used = 156 Mbytes.
    Notice from spectre during hierarchy flattening.
        The value 'psf' specified for the 'checklimitdest' option will no longer be supported in future releases. Use 'spectre -h' to see other recommended values for the 'checklimitdest' option.
    Warning from spectre during hierarchy flattening.
        WARNING (ASL-6206): "/home/fvlupo/Documents/Supergate/Circuits/testLib/vgauss/veriloga/veriloga.va" 19: I4:  Number of initializer elements (1) does not agree with array size (1024) near line number 19. Correct the problem and try again.
    Time for EDB Visiting: CPU = 256 us, elapsed = 262.022 us.
    Time accumulated: CPU = 74.577 ms, elapsed = 103.423 ms.
    Peak resident memory used = 158 Mbytes.
    Warning from spectre during initial setup.
        WARNING (SPECTRE-8059): `I0': `phase' No such output parameter, terminal, or internal node name.
        WARNING (SPECTRE-8287): Ignoring invalid item `I0:phase' in save statement.
    Notice from spectre during initial setup.
        Ignorevaref=yes is ignored since all nodes are connected to Verilog-A modules.
    Global user options:
             psfversion = 1.4.0
                vabstol = 1e-06
                iabstol = 1e-12
                   temp = -269.15
            multithread = off
                   gmin = 1e-12
                 rforce = 1
               maxnotes = 5
               maxwarns = 5
                 digits = 5
                   cols = 80
                 pivrel = 0.001
               sensfile = ../psf/sens.output
         checklimitdest = psf
                   save = allpub
           saveahdlvars = all
                 reltol = 0.001
                   tnom = 27
                 scalem = 1
                  scale = 1
    Scoped user options:
    Circuit inventory:
                  nodes 4
               inductor 3
                isource 3
               jj_shunt 3
                 vgauss 1
    Analysis and control statement inventory:
                   info 7
                   tran 1
    Output statements:
                 .probe 0
               .measure 0
                   save 2
    Time for parsing: CPU = 871 us, elapsed = 21.683 ms.
    Time accumulated: CPU = 75.478 ms, elapsed = 125.136 ms.
    Peak resident memory used = 161 Mbytes.
    Pre-Simulation Summary
    Transient Analysis `tran': time = (0 s -> 20 ps)
    DC simulation time: CPU = 209 us, elapsed = 215.054 us.
    Opening the PSFXL file ../psf/tran.tran.tran ...
    Important parameter values:
        start = 0 s
        outputstart = 0 s
        stop = 20 ps
        step = 20 fs
        maxstep = 200 fs
        ic = all
        useprevic = no
        skipdc = no
        reltol = 100e-06
        abstol(V) = 1 uV
        abstol(I) = 1 pA
        temp = -269.15 C
        tnom = 27 C
        tempeffects = all
        errpreset = conservative
        method = gear2only
        lteratio = 10
        relref = alllocal
        cmin = 0 F
        gmin = 1 pS
    Output and IC/nodeset summary:
                     save   3       (current)
                     save   4       (voltage)
                     others 268
        tran: time = 512.7 fs    (2.56 %), step = 30.36 fs     (152 m%)
        tran: time = 1.516 ps    (7.58 %), step = 61.85 fs     (309 m%)
        tran: time = 2.632 ps    (13.2 %), step = 158.7 fs     (794 m%)
        tran: time = 3.562 ps    (17.8 %), step = 137.7 fs     (689 m%)
        tran: time = 4.652 ps    (23.3 %), step = 200 fs          (1 %)
        tran: time = 5.652 ps    (28.3 %), step = 200 fs          (1 %)
        tran: time = 6.652 ps    (33.3 %), step = 200 fs          (1 %)
        tran: time = 7.652 ps    (38.3 %), step = 200 fs          (1 %)
        tran: time = 8.652 ps    (43.3 %), step = 200 fs          (1 %)
        tran: time = 9.652 ps    (48.3 %), step = 200 fs          (1 %)
        tran: time = 10.65 ps    (53.3 %), step = 200 fs          (1 %)
        tran: time = 11.65 ps    (58.3 %), step = 200 fs          (1 %)
        tran: time = 12.65 ps    (63.3 %), step = 200 fs          (1 %)
        tran: time = 13.65 ps    (68.3 %), step = 200 fs          (1 %)
        tran: time = 14.65 ps    (73.3 %), step = 200 fs          (1 %)
        tran: time = 15.65 ps    (78.3 %), step = 200 fs          (1 %)
        tran: time = 16.65 ps    (83.3 %), step = 200 fs          (1 %)
        tran: time = 17.65 ps    (88.3 %), step = 200 fs          (1 %)
        tran: time = 18.65 ps    (93.3 %), step = 200 fs          (1 %)
        tran: time = 19.65 ps    (98.3 %), step = 200 fs          (1 %)
    Number of accepted tran steps =             146
    Maximum value achieved for any signal of each quantity:
    V: V(I11:idt0) = 155.5 mV
    I: I(I11:lshunt_M_flow) = 6.7 uA
    Post-Transient Simulation Summary
       -   To further speed up simulation, consider
              add ++aps on command line
       -   Non-default settings that could significantly slow down simulation
              errpreset = conservative, default moderate
    During simulation, the CPU load for active processors is :
             0 (8.3 %)       7 (15.4 %)     10 (7.7 %)      11 (7.7 %)
            12 (14.3 %)     16 (45.5 %)     19 (9.1 %)      22 (8.3 %)
            23 (16.7 %)     30 (8.3 %)      31 (14.3 %)
            Total: 155.6%
    Initial condition solution time: CPU = 232 us, elapsed = 237.942 us.
    Intrinsic tran analysis time:    CPU = 10.507 ms, elapsed = 16.4571 ms.
    Total time required for tran analysis `tran': CPU = 11.797 ms, elapsed = 17.7519 ms, util. = 66.5%.
    Time accumulated: CPU = 90.097 ms, elapsed = 145.719 ms.
    Peak resident memory used = 167 Mbytes.
    finalTimeOP: writing operating point information to rawfile.
    Opening the PSF file ../psf/finalTimeOP.info ...
    modelParameter: writing model parameter values to rawfile.
    Opening the PSF file ../psf/modelParameter.info ...
    element: writing instance parameter values to rawfile.
    Opening the PSF file ../psf/element.info ...
    outputParameter: writing output parameter values to rawfile.
    Opening the PSF file ../psf/outputParameter.info ...
    designParamVals: writing netlist parameters to rawfile.
    Opening the PSFASCII file ../psf/designParamVals.info ...
    primitives: writing primitives to rawfile.
    Opening the PSFASCII file ../psf/primitives.info.primitives ...
    subckts: writing subcircuits to rawfile.
    Opening the PSFASCII file ../psf/subckts.info.subckts ...
    Lic Summary:
    [13:27:14.275016] Cdslmd servers:5280@SeeQCNapoli
    [13:27:14.275025] Feature usage summary:
    [13:27:14.275025] Virtuoso_Spectre
    Aggregate audit (1:27:14 PM, Mon Feb 20, 2023):
    Time used: CPU = 93.4 ms, elapsed = 224 ms, util. = 41.7%.
    Time spent in licensing: elapsed = 12.5 ms, percentage of total = 5.56%.
    Peak memory used = 168 Mbytes.
    Simulation started at: 1:27:14 PM, Mon Feb 20, 2023, ended at: 1:27:14 PM, Mon Feb 20, 2023, with elapsed time (wall clock): 224 ms.
    spectre completes with 0 errors, 4 warnings, and 3 notices.
    ********* LOG ENDS **************
    Ah, sorry. I'd missed the fact that you were talking about the "Get from simulation" button; that's calling Spectre separately. Let me check what that does differently.
    OK, I've reproduced the problem. It seems that pressing the "Get from simulation" button runs a small DC simulation to retrieve the available operating point parameters, and does this by using a small OCEAN script. This doesn't use the high performance simulation options from the ADE UI to control which simulator mode is used, but instead uses the default. So even If I manually change from APS back to Spectre on the form, it still runs the "get from simulation" simulation using APS.
    If however you change the default using:
    (which can be typed in the CIW or loaded from your .cdsinit), and then press the "get from simulation" button, it then works OK - because that has changed the default too.
    Let me know if that solves the problem for you.
