  3. QRC error undefined symbol: _ztin12openaccess_418oaconf...
  • Views 1542
QRC error undefined symbol: _ztin12openaccess_418oaconflictobserverins_8oaappdefelj0eee
KhaledHasan
KhaledHasan over 3 years ago
Hi All,
I am running qrc using Quantus EXT191 which throws the below error.
Is this because of any wrong bashrc file path? I'm using IC6.17 with pvs191 and the qrc portion of bashrc includes-
export PATH=$PATH:$QRC_HOME/bin
export QRC_MOS_LW_PRECISION=Y
Will be helpful if you could kindly suggest any solution.
thanks
    My guess is that you have the OA_HOME environment variable set - remove the definition of OA_HOME in your bashrc and in any existing terminal type "unset OA_HOME" or "unsetenv OA_HOME".
