  3. Fetch the "pass/near/fail" result for use in other expressions...
  • Views 1828
Fetch the "pass/near/fail" result for use in other expressions?
TempViator
TempViator over 3 years ago
Hi
In ADE Assembler, is there a way to capture the results of specs (pass/near/fail) to use them to make summary expressions?
Currently, I have a setup like this:
expr1    spec1
expr2   spec2
expr3   spec3
Then I'd like to use these to create a function that tells me that all passed, or certain combinations failed, etc.
In some cases, this might be achieved by creating one giant function, but that makes the expression complexity very high.
This question was asked about 5 years ago, the thread was locked. Andrew Beckett answered that he put in a suggestion to request supporting this function, CCR 1780084...but I don't know if such capability was implemented.
Thanks!
    That enhancement still hasn't been made - so far there was only one request for this.
    Note that using the conditions in run plans allows for you to control whether the next run is run or not dependent upon the pass/fail of selectable outputs, but there's nothing to give a clean summary of the status. If you are doing this as some kind of post-processing, you can use maeGetSpecStatus() or maeGetOverallSpecStatus() - perhaps these will do what you want?
  • TempViator
    TempViator over 3 years ago in reply to Andrew Beckett
    Thanks for the reply, Andrew. I have not done a lot with post-processing and scripting... I think I have a new angle to approach what I am seeking.  It is not quite the same subject, so I will make a new question/thread of it.
