  3. "ERROR`` in cadence license (The desired vendor daemon is...
  • Views 5190
"ERROR`` in cadence license (The desired vendor daemon is down)
Upendra Ch
Upendra Ch over 3 years ago
Hello all,
I am facing the problem in cadence license issue. It is showing like "failed to launch the application because the license required to initialize Virtuoso Framework is not available". To resolve these issue, what procedure we need to follow. Please help in this regard.
Thank You,
    The error message is pretty clear. You need to look in the license server log file, and quite likely re-start the license server.
  • Upendra Ch
    Upendra Ch over 3 years ago in reply to Andrew Beckett
    Thank You.
