  3. Transient Simulation
  • Views 8147
amssshubham
amssshubham over 3 years ago
Does the dynamic parameter allow changing only one parameter during .tran? Is there a way to change multiple variables using the dynamic parameter option?
    Absolutely. In the dynamic parameter section choose Parameter Set and then pick the Param from the cyclic menu and hit Add. In this case I added errpreset and temp to illustrate it. If it was a design variable, you can type in the variable name in the box to the left of the Add button:
