  3. Pnoise on signal at multiple of the fundamental
  • Views 9266
david73
david73 over 3 years ago
Let's say I have a clock circuit where the lowest frequency is 1Ghz, but the I want to measure the jitter on a 2Ghz signal. This means that the main signal will have two cycles in the PSS simulation, and it seems to me that the noise will be folded into the spectrum up to half the fundamental, meaning 0.5Ghz. In the end, what I want is an accurate jitter measurement on the 2Ghz signal. Is it possible?
    Andrew Beckett over 3 years ago +1
    See How to use the field "Sample Ratio" in pnoise type "sampled(jitter)" Andrew
  • david73
    david73 over 3 years ago in reply to Andrew Beckett
    This looks like it's exactly what I need, when was this introduced?
    Andrew Beckett over 3 years ago in reply to david73
    At least 10 years ago (it was in MMSIM13.1 - that was the earlier version I could lay my hands on to check - the sampleratio parameter existed then at least).
