  3. Simulation fails to start when using variable1=calcVal(...
  • Subscribers 136
  • Views 4254
Simulation fails to start when using variable1=calcVal()+variable
msharma
msharma over 3 years ago
In my explorer, I have an 'ac' testbench and an 'tran' testbench. I am using the ac simulation to quickly get the circuit bandwidth, and adjust the input frequency in the tran sim based on the ac simulation. But for a corner, I need to add or subtract a small constant (ac_temp_factor). Here are my expressions:
fsin=calcVal("bw3db_ac" "testLib:calcVal_TEST:ac" ?getFirstSweepPoint   t)+1.0*ac_temp_factor
ac_temp_factor=-1*(temp==-40)+1*(temp==125)  (set separately in the corners form)
However, I get an error at the start of the simulation:
Error found by spectre during circuit read-in.
    ERROR (SFE-874): "input.scs" 10: Cannot run the simulation because syntax error `Unexpected quoted string ""testLib:calcVal_TEST:ac". Expected close parenthesis' was encountered at line 10, column 28. Correct the syntax error and rerun the simulation.
    ERROR (SFE-683): "input.scs" 10: Badly formed parameters statement.
If I replace ac_temp_factor with constant, calcVal("bw3db_ac" "testLib:calcVal_TEST:ac" ?getFirstSweepPoint t)+1.0, the sim runs OK, but if I use the variable ac_temp_factor I get this error.
input.scs:
// Point Netlist Generated on: Mar  1 18:17:08 2023
// Generated for: spectre
// Design Netlist Generated on: Mar  1 17:45:47 2023
// Design library name: testLib
// Design cell name: calcVal_TEST
simulator lang=spectre
global 0
parameters ac_temp_factor=-1*(temp==-40)+1*(temp==125) \
    fsin=calcVal("bw3db_ac" "testLib:calcVal_TEST:ac" ?getFirstSweepPoint \
    t)+ac_temp_factor
include "netlist"
    iabstol=1e-12 temp=-40 tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 \
    rforce=1 maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
    sensfile="../psf/sens.output" dochecklimit=no checklimitdest=psf
tran tran stop=1u write="spectre.ic" writefinal="spectre.fc" \
    annotate=status maxiters=5
File netlist:
// Library name: evros_wl_tpc_sim
// Cell name: calcVal_TEST
// View name: schematic
R0 (IN OUT) resistor r=1e3
C0 (OUT 0) capacitor c=1e-9
V0 (IN 0) vsource dc=0 mag=1 type=sine ampl=1 freq=fsin
    ShawnLogan over 3 years ago
    Dear msharma,
    Please allow me to make an alternate suggestion which I think will avoid the issue. In lieu of defining ac_temp_factor in your corners setup,  include it as a design variable with a conditional expression. Then in your corners setup it will be setup automatically and in your calcVal expression, you may use the variable directly.
    So, in your design variable, it is defined as something like the following where mytemp is your design variable for the simulation temperature:
    ac_temp_factor = case(VAR("my temp")( -40 -1)(125 1))
    Other conditional syntax are shown at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AE15CEAT&pageName=ArticleContent
    Shawn
  • msharma
    msharma over 3 years ago in reply to ShawnLogan
    Dear Shawn,
    Thanks for suggestion. I will try this and let everyone know.
    Do you know if we can also compare strings in such conditional statements? I could not make that work.
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    You can't do 1*(temp==-40) safely, because the calcVal() needs to be interpreted in SKILL (since the simulator doesn't understand it), and in SKILL temp==-40 does not return a number but a boolean. It might work (I haven't tested it) using:
    -1*if(temp==40 1 0)+1*if(temp==125 1 0)
    To answer your question you typed as I was writing this, you should be able to have string targets in a SKILL case statement - i.e. using Shawn's example:
    ac_temp_factor = case(VAR("myVar")("abc" -1)("def" 1))
  • msharma
    msharma over 3 years ago in reply to Andrew Beckett
    OK thanks for addressing the original and subsequent question, Andrew.
    I will try these.
