  3. ANARRAY Layer
  • Views 7933
ANARRAY Layer
Ali Nikoofard
Ali Nikoofard over 3 years ago
ANARRAY is layer that I should be able to see in virtuoso layout Layers (according to PDK) when I search for it, however I don't (I do see ARRAY_VT though), I do have the GDS for the layer but don't know how to search using that. Any help would be appreciated. I understand that you might point out to PDK setup, but I guess that is setup correctly.
    In the layer palette in the layout window, uncheck the "Valid" checkbox near the top (you'll see lots of red layers if you do this) and then in the Filter box type "ANARRAY" or even "ARRAY" (if you use the drop-down next to the search box to pick substring):
    Of course, if you don't find the layer, you should speak to the PDK provider.
