  3. How to derive edge phase noise from Output Noise in sampled...
  • Replies 11
  • Subscribers 139
  • Views 22841
How to derive edge phase noise from Output Noise in sampled Pnoise simulation
mxm14
mxm14 over 3 years ago
I m driving a buffer with a clock of 7 GHz, launching a pss simulation and  pnoise sampled at the rising edge of the output ( threshold set at 0).
I obtained the following graph for output noise and edge phase noise
the two spectra differs of 13dB that i suppose be the power of the carrier since i consider:
dbC= 10log( Pnoise/Pc)= 10logPnoise - 10log(Pc)= Output Noise Spectrum -10log(Pc)
so 10log(Pc)=13dB
if I plot the spectrum of the rms output clock i obtain:
so if i consider Pc=Vrms^2 i  have
10log(Pc)= -7.87dB
It s not clear for me how the edge phase noise is obtained....What i m doing wrong?
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago in reply to ShawnLogan
    One should keep in mind that pnoise and jitter are linear analyses (around a periodic operating point), just like pac and pxf. This means that their results are only accurate as long as the noise amplitudes are small enough so that this linear approximation is valid.
