  3. ERROR: Simualtion issue on EMX
  • Views 13628
Upendra Ch
Upendra Ch over 3 years ago
Hello all,
When I am simulating the EMX. It is not able to RUN and the error/problem is shown in the below-attached image. Please look into it. Kindly reply If you know. It will be helpful in this regard.
Thank You,
Regards
Upendra Ch
Simulation_probelem_in_EMX
  • Ali Nikoofard
    Ali Nikoofard over 3 years ago
    It seems like EMX is not capable of finding the label "MINUS", usually selecting cadence pins in advanced options solves the problem, though I believe the pin you create in the layout should match the layer of the conductor that is connected to. It would be helpful if you can share snapshot of how you defined the pin in the layout!
    -Ali
  • Upendra Ch
    Upendra Ch over 3 years ago in reply to Ali Nikoofard
    Thank you for your reply, and I have attached the images of the layout.
    Andrew Beckett over 3 years ago in reply to Upendra Ch
    It appears that the pins are being identified because the text appears in the gdsview output (I'm guessing you have pins rather than labels, and have set up the EMX form to set the pins). It's hard to know how you've set things up though - so I would suggest contacting customer support so that somebody can look at this with you; that would be the most efficient. After logging into the support site, you can create a support case.
