  3. check instance binding layout Vs Schematic
  • Views 10374
jaapvds
jaapvds over 3 years ago
I would like to check per instance the binding (XL compliancy) between Layout and Schematic.
Function bndGetBoundObjects can be used for this purpose, like:
foreach(insts cvId~>instaces
   bndGetBoundObjects(insts)
However this must be ran in XL mode
To overcome this, function lxRunCmdInXL should be used, however when using:
  lxRunCmdInXL(cvId  'bndGetBoundObjects insts)
I get the error: *Error* lxRunCmdInXL: extra arguments or keyword missing - ((db:0x5d0ef89a db:0x5d0ef89b))
What extra argument must be added?
Thanks!
    Two issues:
    1. You need to pass the argument list to lxRunCmdInXL with ?cmdArgs (which needs to be a list)
    2. The function always gets passed the layout and schematic cellView ids.
    You could do:
    procedure(MyWrapBndGetBoundObjects(_d1 d2 instId)
      bndGetBoundObjects(instId)
    bindings=foreach(mapcar inst cv~>instances lxRunCmdInXL(cv  'MyWrapBndGetBoundObjects ?cmdArgs list(inst)))
    However, it is probably best to just to "run in XL" once (this will be much quicker, as XL only gets initialised a single time):
    procedure(MyGetAllBindings(lcv _scv)
      foreach(mapcar inst lcv~>instances bndGetBoundObjects(inst))
    bindings=lxRunCmdInXL(cv 'MyGetAllBindings)
  • jaapvds
    jaapvds over 3 years ago in reply to Andrew Beckett
    thanks Andrew for quick reply, this works!
    Kind Regards,
    Jaap
  • jaapvds
    I have following instances in my design:
    Bound M0 - MOS transistor from Foundry lib
    Bound M1 - MOS transistor from Foundry lib
    UnBound I0
    UnBound I1
    Bound PIN0 - VDD pin from analog lib
    Bound PIN1 - gnd pin from analog lib
    output from bindings=lxRunCmdInXL(cv 'MyGetAllBindings):
    ((((db:0x5f13c59a 0 0 0)))
    (((db:0x5f13c59b 0 0 0))) nil nil
    ((db:0x5f13129a))
    ((db:0x5f13129b))
    I suppose the two 'nil' in the output indicate the unbound instances I0/I1?
    (db:0x5f13c59a 0 0 0)  and (db:0x5f13c59b 0 0 0)) - indicates M0/M1
    and
    (db:0x5f13129a) and db:(0x5f13129b) - indicates PIN1/PIN0
    So why are differences between MOS (db object and 2 '0') and PIN with only db objects?
    Because if I extend your procedure with:
    foreach(mapcar insts lcv~>instances
    totalInsts = totalInsts+1
    boundUnbound = 0
    if(bndGetBoundObjects(insts) then
    listGbound = cons(insts listGbound)
    printf("Bound Inst %s \n" insts~>name)
    printf("Bound Schem Inst %s \n" caaar(bndGetBoundObjects(insts))~>name)
    else
    listUbound = cons(insts listUbound)
    printf("Unbound Inst %s \n" insts~>name)
    ); if
    ) ;foreach
    I get the following error message:
    Bound M0
    Bound M1
    UnBound I0
    UnBound I1
    *Error* car: Can't take car of atom - db:0x5f13129a
    Any idea how to solve this?
    thanks!
    Jaap
    Andrew Beckett over 3 years ago in reply to jaapvds
    Not sure which direction you're going in, but using bndGetBoundObjects on a schematic pin will give the corresponding layout terminal and vice versa. These are not returned as a list in the same way because they don't need to have either a hierarchical path nor would they need the array indices that you get with instances. Your code has caaar(bndGetBoundObjects(insts))~>name) which assumes that has the list structure for an instance.
    The documentation seems to not mention this - it probably should... (I've fed that back to tech pubs).
