  3. Is it possible to do transient simulation with and without...
  • Subscribers 136
  • Views 9377
Is it possible to do transient simulation with and without transient noise in one go?
delgsy
delgsy over 3 years ago
I want to do a transient simulation with and without transient noise.
Is it possible to do these in one go?
So, basically it is like config sweep, but for transient noise.
    Andrew Beckett over 3 years ago in reply to StephanWeber +1
    StephanWeber said: I think using isnoisy as dynamic parameter in a transient noise analysis is also a good way. This way you can avoid having noise e.g. during circuit startup part. Can save a lot of time…
    In the transient noise analysis, set noisefmax to be VAR("FMAX"), say. Then you can sweep the variable FMAX to be 0,4G (for example). With it set to 0, transient noise will be off; with set to 4G, it would be 4GHz.
  • StephanWeber
    StephanWeber over 3 years ago in reply to Andrew Beckett
    I think using isnoisy as dynamic parameter in a transient noise analysis is also a good way. This way you can avoid having noise e.g. during circuit startup part. Can save a lot of time.
    That is of course true, but it isn't really what delgsywas asking (as far as I can see).
  • delgsy
    delgsy over 3 years ago in reply to Andrew Beckett
    I think your solution will work.
    I have tried using VAR("FMAX") before but never tried to plug 0 as a value.
    If this is possible, then it fulfills what I need.
