  3. Measurements across montecarlo
  • Views 7698
sandrone
sandrone over 3 years ago
Hi all,
I'm using IC6.1.8 and within ADE-XL I'm trying to perform the usual ymin ymax etc. operations on the results of a montecarlo sim. I followed the same procedure used for the corners sims, changing the EvalType to corners and working on the "blue expressions", but that did not work, I get a result for each mc run and not a global one. I also tried treating the montecarlo sim as a corner sim, adding it to the Corners list and selecting the montecarlo section of the model file in the Corners Setup menu (although Run Mode is Montecarlo Sampling and not Single Run, Sweep and Corners), but the result is the same. So my question is: am I doing something wrong or such measurements can be performed only on proper corners?
Thank you in advence for your help!
s.
