  3. Analog Lib Switch
  • Subscribers 136
  • Views 12290
Analog Lib Switch
IEEE
IEEE over 3 years ago
I have a simple VIN voltage divider of two resistors, Rtop and Rbottom.
VIN is rise from 0 to 5V.
I want the output don’t pass 1V, mean when VIN>2V VOUT=1V. when VIN<2V, VOUT=0.5*VIN
How to use analog lib ideal switch?
What to connect to all four terminal(N+,NC+,N-,NC-) ? What closed\open voltage to use? What R open Rclose to use?
    ShawnLogan over 3 years ago
    Dear IEEE,
    I am not sure if you viewed the Forum post at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/41952/using-the-switch-in-the-analoglib
    It has an example of its use that I think will provide some helpful information.
    Shawn
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    Also look at (from the command line) "spectre -h relay" (the analogLib switch component is the spectre "relay" component). You seem to have connected it up in a rather strange way. The voltage on the controlling input controls whether the switch is open or closed, and then you can choose the resistance when open or closed.
