  3. ViVA : Save image issue
  • Views 9359
StephanWeber
StephanWeber over 3 years ago
I run Assembler with 3 Tests, and do a plot all. Now I want to export a png file. It works, but if I select Multiple Files the Save button is grayed out.
By default, I got multiple plots, like from AC, DC, Tran analysis, but the best would be having these individual plots in a separate file.
I also struggle with saving the images from all 3 tests with one click, looks that export is only per Test.
Bye Stephan
    Stephan,
    This is just if you have multiple sub windows and you've picked "All sub windows using [Multiple Files]'. Try picking the drop-down in the File Names field. You'll see there is a choice of $SUBWIN or $TRACE - if you pick one of these, or enter a file such as save$SUBWIN.png it will work. The idea is that you need to provide the mechanism by which to name the files.
  • StephanWeber
    StephanWeber over 3 years ago in reply to Andrew Beckett
    This is cool, I get now excactly what I needed. Using $TRACE is also good because then the names include the signal names, not only window numbers.
    Bye Stephan
