  3. Assembler MC: When is combine button available?
  • Views 8138
StephanWeber
StephanWeber over 3 years ago
I run MC at nominal and one more corner (T=125C), but I want the histograms for nom and this 2nd corner in one plot. I remember this is possible, but why is the button "Combine" grayed out?
I also wonder about plotting template, can I switch combine option (when it works) afterwards, or do I need 2 plotting template to get with one separated histos, and in the other combine?
Bye Stephan
    Andrew Beckett over 3 years ago +1
    You just need to select the corners (or sweep points) that you want to combine, and then the combine button gets un-greyed: Andrew
  • StephanWeber
    StephanWeber over 3 years ago in reply to Andrew Beckett
    Many thanks!
