  3. Run Quantus fails: depending on which account it is being...
  • Subscribers 137
  • Views 10249
Run Quantus fails: depending on which account it is being used from
gaddan14
gaddan14 over 3 years ago
Hello
I am a professor teaching a 4th-year course on VLSI design. This year, I added a new lab requiring parasitic extraction using QUANTUS. The lab experiment runs without any error if I run it from my own account.
However, all students in the lab reported an error when they went through the same procedure and in the same environment, I think.
Here is the error message
ERROR (LBMISC-215052): cannot create np_rpoly_conn: No such file or directory
ERROR (REX-163152): /CMC/tools/cadence/QUANTUS20.12.000_lnx86/tools.lnx86/extraction/bin/64bit//geom failed with status 255
ERROR (LBRCXM-609): Bad return status from RCX run. 0xff00
ERROR (LBRCXM-709): ***** Quantus terminated abnormally *****
I uploaded two log files,  the first one is the error-free log file, and the other one is the error log file.
I would appreciate any help in this reagrd
Fullscreen QUNATUS_No_Error.txt Download
  Cadence Quantus Extraction - 64-bit Parasitic Extractor - Version
20.1.2-p025 Thu Sep 3 13:54:09 PDT 2020
                                 Copyright 2020 Cadence Design Systems,
Inc.
WARNING (EXTQRCXOPT-381) : The output_db -hierarchy_delimiter option value cannot be an empty string.
It is now set to be the same as that of the input_db -hierarchy_delimiter
option. If input_db -hierarchy_delimiter is not set, then output_db
-hierarchy_delimiter is set to the default value ("/" character).
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
 /CMC/tools/cadence/ASSURA04.16.111-618_lnx86/tools.lnx86/assura/bin/avRCXxref /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/__qrc.rcx_cmd -useRunName
@(#)$CDS: avRCXxref_64 version av4.1:Production:dfII6.1.8-64b:IC6.1.8-64b.500.17 03/26/2021 10:22 (sjfhw780) $
sub-version 4.1_USR6_HF11, integ signature 2021-03-26-0950
run on macvm at Wed Mar 29 04:27:53 2023
Reading rsf
INFO (LBRCXU-114): Finished /CMC/tools/cadence/ASSURA04.16.111-618_lnx86/tools.lnx86/assura/bin/avRCXxref
INFO (LBRCXM-630): Starting extraction: Wed Mar 29 04:27:53 2023
Forking:  capgen -techdir /home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical -inc /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run.elf -lvs /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run.xcn -p2lvs /home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical/qrcTechFile -reseqn -p poly_conn,allGate,Oxide -canonical_res_caps -length_units meters -exclude_gate_res -cap_ground_layer psubstrate /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run
INFO (LBMISC-215205):
*** Cadence Quantus Extraction Techgen -trans VERSION 20.1.2 Linux 64 bit - (Thu Sep 3 13:54:09 PDT 2020)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run
INFO (CAPGEN-41737): Lvs connect layers Bondpad CapMetal ind10 ind11 npn_emit pnp_emit are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by ind10 layers SPK_T?479 are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by ind11 layers SPRL_T?478 are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by nb_tap layers Nburied are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by ndiff_conn layers ntap are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by nwell_conn layers nb_tap are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by pdiff_conn layers ptap are not mapped in layer_setup file
INFO (CAPGEN-41804): Lvs stamped by ptap layers pwell are not mapped in layer_setup file
WARNING (RCXSPIC-27104): p2lvsfile in tech directory does not have resistance
 temperature coefficients (TC1, TC2). ?temperature is ignored
rcxspice took  0.03 user, 0.01 sys, 0.00 elapsed, 7072.0 kbytes
Successfully created RCX script '/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/rcx.sh'
INFO (LBRCXM-581): Checked out '1' license(s) of QTS300 20.10
INFO (LBRCXM-608): Executing command
   /bin/ksh  /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/rcx.sh
##ADD_EXPLICIT_VIAS=N
##ADD_BULK_TERMINAL=N
##AGDS_FILE=/dev/null
##AGDS_LAYER_MAP_FILE=/dev/null
##HCCI_DEV_PROP_FILE=/dev/null
##AGDS_SPICE_FILE=/dev/null
##AGDS_TEXT_LAYERS=
##ARRAY_VIAS_SPACING=
##ASSURA_RUN_DIR=/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS
##ASSURA_RUN_NAME=NOR3_compact_LVS_run
##BLACK_BOX_CELLS=/dev/null
##BREAK_WIDTH=
##CAP_COUPLING_FACTOR=1.0
##CAP_EXTRACT_MODE=coupled
##CAP_GROUND=Vss
##CAP_MODELS=no
##DANGLINGR=N
##DENSITY_CHECK_METHOD=P
##DELETE_OUTPUT_FILE=N
##DEVICE_FINGER_DELIMITER='@'
##DF2=N
##DRACULA_RUN_DIR=
##DRACULA_RUN_NAME=
##ENABLESENSITIVITYEXTRACTION=N
##EXCLUDE_FLOAT_LIMIT=
##EXCLUDE_FLOAT_DECOPULING_FACTOR=
##EXCLUDE_FLOATING_NETS=N
##EXCLUDE_NETS_REDUCERC=/dev/null
##EXCLUDE_SELF_CAPS=Y
##IGNORE_GATE_DIFFUSION_FRINGING_CAP=Y
##EXTRACT=both
##EXTRACT_MOS_DIFFUSION_AP=N
##EXTRACT_MOS_DIFFUSION_HIGH=
##EXTRACT_MOS_DIFFUSION_RES=N
##FILTER_SIZE=2.0
##FIXED_NETS_FILE=/dev/null
##FMAX=
##FRACTURE_LENGTH_UNITS=MICRONS
##FREQUENCY_FILE=/dev/null
##GROUND_NETS=
##GROUND_NETS_FILE=/dev/null
##GROUND_SUBSTRATE_FLOATING_NETS=N
##HCCI_DEV_PROP=7
##HCCI_INST_PROP=6
##HCCI_NET_PROP=5
##HCCI_RULE_FILE=
##HCCI_RUN_DIR=
##HCCI_RUN_NAME=
##HEADER_FILE=/dev/null
##HIERARCHY_DELIMITER='/'
##OUTPUT_HIERARCHY_DELIMITER='/'
##HRCX_CELLS_FILE=/dev/null
##IMPORT_GLOBALS=Y
##LADDER_NETWORK=N
##LVS_SOURCE=assura
##M_FACTORR=
##M_FACTORW=N
##MACRO_CELL=Y
##MAX_FRACTURE_LENGTH=infinite
##MAX_SIGNALS=
##MERGE_PARALLEL_R=N
##MERGE_PARALLEL_VIA=N
##MINC=1e-17
##MINC_BY_PERCENTAGE=0.1
##MINR=0.001
##NET_NAME_SPACE=layout
##NETS_FILE=/dev/null
##OUTPUT=/home/egad/Shared/ELG4137/NOR3_compact_LVS_run.sp
##OUTPUT_NET_NAME_SPACE=schematic
##PARASITIC_BLOCKING_DEVICE_CELLS_TYPE=gray
##PARASITIC_CAP_MODELS=no
##PARASITIC_RES_MODELS=comment
##PARASITIC_RES_LENGTH=N
##PARASITIC_RES_WIDTH=N
##PARASITIC_RES_WIDTH_DRAWN=N
##PARASITIC_RES_UNIT=N
##PARTIAL_CAP_BLOCKING=N
##PEEC=N
##PIN_ORDER_FILE=/dev/null
##PIPE_ADVGEN=
##PIPE_SPICE2DB=
##POWER_NETS=
##POWER_NETS_FILE=/dev/null
##RC_FREQUENCY=
##RCXDIR=/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run
##RCXFS_HIGH=N
##RCXFS_NETS_FILE=
##RCXFS_TYPE=none
##RCXFS_CUTOFF_DISTANCE=
##RCXFS_VIA_OFF=N
##REDUCERC=N
##REGION_LIMIT=
##RES_MODELS=no
##RISE_TIME=
##SAVE_FILL_SHAPES=N
##SINGLE_CAP_EDSPF=N
##SHOW_DIODES=N
##SKIN_FREQUENCY=
##SPEF=N
##SPEF_UNITS=
##SPLIT_PINS=N
##FORCE_SUBCELL_PIN_ORDERS=N
##SPLIT_PINS_DISTANCE=
##SUB_NODE_CHAR='#'
##SUBSTRATE_PROFILE=/dev/null
##SUBSTRATE_STAMPING_OFF=N
##TEMPDIR=/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/rcx_temp
##TEMPERATURE=25.0
##TYPE=full
##USER_REGION=/dev/null
##VARIANT_CELL_FILE=/dev/null
##VIA_EFFECT_OFF=N
##VIRTUAL_FILL=
##XREF=/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/NOR3_compact_LVS_run.gnx,/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/NOR3_compact_LVS_run.gdx
##XY_COORDINATES=
CASE_SENSITIVE=TRUE
export CASE_SENSITIVE
QRC_MOS_LW_PRECISION=y
export QRC_MOS_LW_PRECISION
TEMPDIR=`setTempDir /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/rcx_temp`
export TEMPDIR
cd /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run
cat <<ENDCAT> caps2dversion
* caps2d version: 10
ENDCAT
cat <<ENDCAT> flattransUnit.info
meters
ENDCAT
QRC=Y
export QRC
cat <<ENDCAT> topcellxcn.info
ENDCAT
# Generate RCX input data from Assura LVS database
GOALIE2DIR=/CMC/tools/cadence/QUANTUS20.12.000_lnx86/tools.lnx86/extraction/bin
export GOALIE2DIR
vdbToRcx /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS \
	NOR3_compact_LVS_run -unit meters -- -V1 -H satfile -r \
	/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run.xcn \
	-xgl
@(#)$CDS: vdbToRcx_64 version av4.1:Production:dfII6.1.8-64b:IC6.1.8-64b.500.17 03/26/2021 10:28 (sjfhw780) $
20.1.2 Linux 64 bit - (Tue Mar 9 20:41:29 PST 2021)
Opening LVS data for NOR3_compact_LVS_run in /home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS
Open time is 0.0 sec.
Build pins/attributes took 0.0 sec.
Processing poly_conn_pintext                     0 shapes 0.0 sec.
Processing metal2_conn_pintext                   1 shapes 0.0 sec.
Processing metal1_conn_pintext                   5 shapes 0.0 sec.
create satfile took  0.01 user, 0.00 sys, 0.00 elapsed, 138104.0 kbytes
write edge poly_conn_pintext took  0.00 user, 0.00 sys, 0.00 elapsed, 138364.0 kbytes
write edge metal2_conn_pintext took  0.00 user, 0.00 sys, 0.00 elapsed, 138380.0 kbytes
write edge metal1_conn_pintext took  0.00 user, 0.00 sys, 0.00 elapsed, 138396.0 kbytes
Building net map file.		0.0 sec.
create netmap file took 0.00 user, 0.00 sys, 0.00 elapsed, 138404.0 kbytes
create net file took 0.00 user, 0.00 sys, 0.00 elapsed, 138436.0 kbytes
WARNING (LBCLV-5663): No bipolar models provided. Can't create bipolar files
WARNING (LBCLV-5660): No resistor models provided. Can't create resistor files
WARNING (LBCLV-5654): No capacitor models provided. Can't create capacitor file
WARNING (LBCLV-5657): No diode models provided. Can't create diode files
WARNING (LBCLV-5706): no generic models in rule file
Device creation took 0.0 sec
Processing cont_ndiff                           24 shapes 0.0 sec.
write edge cont_ndiff took  0.00 user, 0.00 sys, 0.00 elapsed, 138876.0 kbytes
Processing Via1                                  2 shapes 0.0 sec.
write edge Via1 took  0.00 user, 0.00 sys, 0.00 elapsed, 139076.0 kbytes
Processing cont_pdiff                           38 shapes 0.0 sec.
write edge cont_pdiff took  0.00 user, 0.00 sys, 0.00 elapsed, 139216.0 kbytes
Processing cont_poly                             3 shapes 0.0 sec.
write edge cont_poly took  0.00 user, 0.00 sys, 0.00 elapsed, 139372.0 kbytes
write edge _pmos1v_MOS_10 took  0.00 user, 0.00 sys, 0.00 elapsed, 139512.0 kbytes
write edge _nmos1v_MOS_2 took  0.00 user, 0.00 sys, 0.00 elapsed, 139660.0 kbytes
Processing _pmos1v_MOS_10                        3 shapes 0.0 sec.
Processing _nmos1v_MOS_2                         3 shapes 0.0 sec.
Processing pwell                                 1 shapes 0.0 sec.
write edge pwell took  0.00 user, 0.00 sys, 0.00 elapsed, 139800.0 kbytes
Processing ptap                                  1 shapes 0.0 sec.
write edge ptap took  0.00 user, 0.00 sys, 0.00 elapsed, 139940.0 kbytes
Processing ntap                                  3 shapes 0.0 sec.
write edge ntap took  0.00 user, 0.00 sys, 0.00 elapsed, 140080.0 kbytes
Processing ndiff_conn                            9 shapes 0.0 sec.
write edge ndiff_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 140220.0 kbytes
Processing poly_conn                             3 shapes 0.0 sec.
write edge poly_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 140360.0 kbytes
Processing pdiff_conn                            7 shapes 0.0 sec.
write edge pdiff_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 140588.0 kbytes
Processing nwell_conn                            3 shapes 0.0 sec.
write edge nwell_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 140728.0 kbytes
Processing metal2_conn                           1 shapes 0.0 sec.
write edge metal2_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 140868.0 kbytes
Processing metal1_conn                           9 shapes 0.0 sec.
write edge metal1_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 141028.0 kbytes
sort edges took  0.03 user, 0.05 sys, 0.00 elapsed, 2088.0 kbytes
sort edges and labels took  0.18 user, 0.12 sys, 1.00 elapsed, 141188.0 kbytes
	vdbToRcx System Usage:
	Elapsed:     1 seconds.
	CPU:         0.1 seconds
	Memory      32 Meg
GOALIE2DIR=/CMC/tools/cadence/QUANTUS20.12.000_lnx86/tools.lnx86/extraction/bin/64bit/
export GOALIE2DIR
# Calculate erosion tables for specified process layers
densitymap -V -TC -O metal2_conn.den metal2_conn_tile_spec metal2_conn
floatfilename = metal2_conn.flt
densitymap took 0.00 user, 0.00 sys, 0.00 elapsed, 2352.0 kbytes
densitymap -V -TC -O metal1_conn.den metal1_conn_tile_spec metal1_conn
floatfilename = metal1_conn.flt
geom _nmos1v_MOS_2 ndiff_conn - _nmos1v_MOS_2,10,i,1
geom _pmos1v_MOS_10 pdiff_conn - _pmos1v_MOS_10,10,i,1
# Generate power list
cat global.net > power_list
# Ensure vias do not extend beyond routing
geom -V Via1 metal2_conn metal1_conn - Via1,111,i,2
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3324.0 kbytes
geom -V cont_poly metal1_conn poly_conn - cont_poly,111,i,2
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3328.0 kbytes
geom -V cont_pdiff metal1_conn pdiff_conn - cont_pdiff_metal1_conn_pdiff_conn,111,i,2
geom -V cont_ndiff metal1_conn ndiff_conn - cont_ndiff_metal1_conn_ndiff_conn,111,i,2
geom -V ptap pdiff_conn - ptap_pdiff_conn_ovia,11,i,1
geom -V pwell ptap - pwell_ptap_ovia,11,i,1
geom -V ntap ndiff_conn - ntap_ndiff_conn_ovia,11,i,1
geom -V nwell_conn ntap - nwell_conn_ntap_ovia,11,i,1
# Flatten net file, routing, via and device layers
SAVEDIR=`beginFlattenInputs`
beginFlattenInputs
export SAVEDIR
/bin/mv -f NET h_NET
flatnet -V -li -h '/' h_NET NET
flatnet took 0.00 user, 0.00 sys, 0.00 elapsed, 16712.0 kbytes
netprint -V -N1 power_list:power_list_nums NET
flattenTransistorData _nmos1v_MOS_2 meters
flattub took  0.00 user, 0.00 sys, 0.00 elapsed, 9588.0 kbytes
flatnet took 0.00 user, 0.00 sys, 0.00 elapsed, 16684.0 kbytes
flattenTransistorData _pmos1v_MOS_10 meters
flattub took  0.00 user, 0.00 sys, 0.00 elapsed, 9596.0 kbytes
flatnet took 0.00 user, 0.00 sys, 0.00 elapsed, 16676.0 kbytes
flattenLayers -m metal2_conn metal1_conn poly_conn ndiff_conn pdiff_conn \
	nwell_conn Via1 cont_poly cont_pdiff_metal1_conn_pdiff_conn \
	cont_ndiff_metal1_conn_ndiff_conn ptap_pdiff_conn_ovia ptap \
	pwell_ptap_ovia pwell ntap_ndiff_conn_ovia ntap nwell_conn_ntap_ovia \
	cont_pdiff cont_ndiff
flattub took  0.00 user, 0.00 sys, 0.00 elapsed, 3448.0 kbytes
endFlattenInputs
# Initialize CAP_GROUND variable
CAP_GROUND=`findCapGround -g Vss NET`
echo "CAP_GROUND=" ${CAP_GROUND}
CAP_GROUND= 2
export CAP_GROUND
reconnect -cgnd ${CAP_GROUND} -float floatlvsnetsfile -tf \
	_nmos1v_MOS_2,_pmos1v_MOS_10 -probe \
	metal2_conn_pintext:metal2_conn:metal2_conn_pintext_fvia,metal1_conn_pintext:metal1_conn:metal1_conn_pintext_fvia,poly_conn_pintext:poly_conn:poly_conn_pintext_fvia
geom _nmos1v_MOS_2,_pmos1v_MOS_10 - qrcgate,1,i,1
iprint -imerge power_list_nums floatlvsnetsfile power_list_nums2
mv power_list_nums power_list_nums_orig
cp power_list_nums2 power_list_nums
# Segregate interconnect into resistive and non-resistive
selectNetsByNumber power_list_nums metal1_conn p_rmetal1_conn np_rmetal1_conn
epick took  0.00 user, 0.00 sys, 0.00 elapsed, 2084.0 kbytes
selectNetsByNumber power_list_nums metal2_conn p_rmetal2_conn np_rmetal2_conn
selectNetsByNumber power_list_nums ndiff_conn p_rndiff_conn np_rndiff_conn
epick took  0.00 user, 0.00 sys, 0.00 elapsed, 2080.0 kbytes
selectNetsByNumber power_list_nums ntap p_rntap np_rntap
selectNetsByNumber power_list_nums nwell_conn p_rnwell_conn np_rnwell_conn
selectNetsByNumber power_list_nums pdiff_conn p_rpdiff_conn np_rpdiff_conn
selectNetsByNumber power_list_nums poly_conn p_rpoly_conn np_rpoly_conn
selectNetsByNumber power_list_nums ptap p_rptap np_rptap
selectNetsByNumber power_list_nums pwell p_rpwell np_rpwell
selectNetsByNumber power_list_nums Via1 p_rVia1 np_rVia1
selectNetsByNumber power_list_nums cont_poly p_rcont_poly np_rcont_poly
epick took  0.00 user, 0.00 sys, 0.00 elapsed, 2088.0 kbytes
mv power_list_nums_orig power_list_nums
# Create resistor cut regions between resistive
# interconnect levels
mergevia -V -tech /home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical -cnt \
	np_rVia1 rVia1 - np_rmetal2_conn np_rmetal1_conn
mergevia took 0.00 user, 0.00 sys, 0.00 elapsed, 11024.0 kbytes
	np_rcont_poly rcont_poly - np_rmetal1_conn np_rpoly_conn
mergevia took 0.00 user, 0.00 sys, 0.00 elapsed, 11020.0 kbytes
# Create resistive interconnect MOSFET terminals
createNRMosfetGateTerminal _nmos1v_MOS_2 np_rpoly_conn _nmos1v_MOS_2_mgvia
createNRMosfetGateTerminal _pmos1v_MOS_10 np_rpoly_conn _pmos1v_MOS_10_mgvia
# Assign net numbers to cut regions
connect -V -relocate NET np_rndiff_conn:np_rndiff_conn.conn \
	np_rpdiff_conn:np_rpdiff_conn.conn np_rntap:np_rntap.conn \
	np_rnwell_conn:np_rnwell_conn.conn np_rptap:np_rptap.conn \
	np_rpwell:np_rpwell.conn rVia1 rcont_poly _nmos1v_MOS_2_mgvia \
	_pmos1v_MOS_10_mgvia - ntap_ndiff_conn_ovia,3,1 \
	nwell_conn_ntap_ovia,4,3 ptap_pdiff_conn_ovia,5,2 pwell_ptap_ovia,6,5 \
connect took  0.00 user, 0.00 sys, 0.00 elapsed, 271264.0 kbytes
# Assign net numbers to resistor vias
geom -V cont_ndiff_metal1_conn_ndiff_conn np_rndiff_conn.conn - tmp_rcont_ndiff_metal1_conn_ndiff_conn,11,i,2
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3064.0 kbytes
mergevia -V -i -tech /home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical -cnt \
	tmp_rcont_ndiff_metal1_conn_ndiff_conn \
	rcont_ndiff_metal1_conn_ndiff_conn - np_rmetal1_conn np_rndiff_conn
mergevia took 0.12 user, 0.03 sys, 0.00 elapsed, 11024.0 kbytes
/bin/rm -f tmp_rcont_ndiff_metal1_conn_ndiff_conn
geom -V cont_pdiff_metal1_conn_pdiff_conn np_rpdiff_conn.conn - tmp_rcont_pdiff_metal1_conn_pdiff_conn,11,i,2
	tmp_rcont_pdiff_metal1_conn_pdiff_conn \
	rcont_pdiff_metal1_conn_pdiff_conn - np_rmetal1_conn np_rpdiff_conn
mergevia took 0.08 user, 0.02 sys, 0.00 elapsed, 11020.0 kbytes
/bin/rm -f tmp_rcont_pdiff_metal1_conn_pdiff_conn
# Assign net numbers to nonresistive layers
epick -V -reo -e rcont_ndiff_metal1_conn_ndiff_conn -e \
	rcont_pdiff_metal1_conn_pdiff_conn np_rndiff_conn.conn tmp_ndiff_conn
epick -V -reo -e tmp_ndiff_conn -c np_rndiff_conn.conn tmp1_ndiff_conn
geom -V tmp1_ndiff_conn np_rndiff_conn - tmp1_ndiff_conn,11,i,2
geom -V tmp_ndiff_conn,tmp1_ndiff_conn - np_rndiff_conn,1,i,1
/bin/rm -f tmp_ndiff_conn tmp1_ndiff_conn
	rcont_pdiff_metal1_conn_pdiff_conn np_rpdiff_conn.conn tmp_pdiff_conn
epick -V -reo -e tmp_pdiff_conn -c np_rpdiff_conn.conn tmp1_pdiff_conn
geom -V tmp1_pdiff_conn np_rpdiff_conn - tmp1_pdiff_conn,11,i,2
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3060.0 kbytes
geom -V tmp_pdiff_conn,tmp1_pdiff_conn - np_rpdiff_conn,1,i,1
/bin/rm -f tmp_pdiff_conn tmp1_pdiff_conn
	rcont_pdiff_metal1_conn_pdiff_conn np_rnwell_conn.conn tmp_nwell_conn
epick -V -reo -e tmp_nwell_conn -c np_rnwell_conn.conn tmp1_nwell_conn
geom -V tmp1_nwell_conn np_rnwell_conn - tmp1_nwell_conn,11,i,2
geom -V tmp_nwell_conn,tmp1_nwell_conn - np_rnwell_conn,1,i,1
/bin/rm -f tmp_nwell_conn tmp1_nwell_conn
	rcont_pdiff_metal1_conn_pdiff_conn np_rpwell.conn tmp_pwell
epick -V -reo -e tmp_pwell -c np_rpwell.conn tmp1_pwell
geom -V tmp1_pwell np_rpwell - tmp1_pwell,11,i,2
geom -V tmp_pwell,tmp1_pwell - np_rpwell,1,i,1
/bin/rm -f tmp_pwell tmp1_pwell
# Process text layers
flatlabel -V  -tc -F -l flatlabel.info metal2_conn_pintext,metal1_conn_pintext,poly_conn_pintext L1T0,L2T0,L3T0
INFO (FLTLBL-89003): exec labsort -V L1T0
INFO (FLTLBL-89003): exec labsort -V L2T0
INFO (FLTLBL-89003): exec labsort -V L3T0
# 1 np_rpoly_conn
# 2 np_rmetal1_conn
# 3 np_rmetal2_conn
# Parasitic R extraction with default precision
rex -V -m -pd -I'#' -tech /home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical \
	-map p2elayermapfile -wee p2elayermapfile -N NET -Ply np_rpoly_conn \
	-er np_rmetal2_conn,metal2_conn.den:np_rmetal1_conn,metal1_conn.den \
	-rP res.mod np_rpoly_conn::poly_conn_cut::-0.003 \
	np_rmetal1_conn::metal1_conn_cut::s,w:0.06,0.06,0:0.06,0.08,0:0.06,0.09,0:0.06,0.13,0:0.06,0.16,0:0.06,0.19,0:0.06,0.26,0:0.06,0.38,0:0.06,0.5,0:0.06,0.63,0:0.06,0.83,0:0.06,1,0.01:0.06,1.5,0.01:0.06,3,0.01:0.06,4.05,0.01:0.08,0.06,0.01:0.08,0.08,0.01:0.08,0.09,0.01:0.08,0.13,0:0.08,0.16,0.01:0.08,0.19,0:0.08,0.26,0:0.08,0.38,0:0.08,0.5,0:0.08,0.63,0:0.08,0.83,0:0.08,1,0.01:0.08,1.5,0.01:0.08,3,0.01:0.08,4.05,0.01:0.09,0.06,0.01:0.09,0.08,0.01:0.09,0.09,0.01:0.09,0.13,0:0.09,0.16,0.01:0.09,0.19,0:0.09,0.26,0:0.09,0.38,0:0.09,0.5,0:0.09,0.63,0:0.09,0.83,0:0.09,1,0.01:0.09,1.5,0.01:0.09,3,0.01:0.09,4.05,0.01:0.13,0.06,0.01:0.13,0.08,0.01:0.13,0.09,0.01:0.13,0.13,0:0.13,0.16,0.01:0.13,0.19,0:0.13,0.26,0:0.13,0.38,0:0.13,0.5,0:0.13,0.63,0:0.13,0.83,0:0.13,1,0.01:0.13,1.5,0.01:0.13,3,0.01:0.13,4.05,0.01:0.16,0.06,0.01:0.16,0.08,0.01:0.16,0.09,0.01:0.16,0.13,0:0.16,0.16,0.01:0.16,0.19,0:0.16,0.26,0:0.16,0.38,0:0.16,0.5,0:0.16,0.63,0:0.16,0.83,0:0.16,1,0.01:0.16,1.5,0.01:0.16,3,0.01:0.16,4.05,0.01:0.19,0.06,0.02:0.19,0.08,0.01:0.19,0.09,0.01:0.19,0.13,0:0.19,0.16,0.01:0.19,0.19,0:0.19,0.26,0:0.19,0.38,0:0.19,0.5,0:0.19,0.63,0:0.19,0.83,0:0.19,1,0.01:0.19,1.5,0.01:0.19,3,0.01:0.19,4.05,0.01:0.26,0.06,0.02:0.26,0.08,0.01:0.26,0.09,0.01:0.26,0.13,0:0.26,0.16,0.01:0.26,0.19,0:0.26,0.26,0:0.26,0.38,0:0.26,0.5,0:0.26,0.63,0:0.26,0.83,0:0.26,1,0.01:0.26,1.5,0.01:0.26,3,0.01:0.26,4.05,0.01:0.38,0.06,0.02:0.38,0.08,0.01:0.38,0.09,0.01:0.38,0.13,0:0.38,0.16,0.01:0.38,0.19,0:0.38,0.26,0:0.38,0.38,0:0.38,0.5,0:0.38,0.63,0:0.38,0.83,0:0.38,1,0.01:0.38,1.5,0.01:0.38,3,0.01:0.38,4.05,0.01:0.63,0.06,0.02:0.63,0.08,0.01:0.63,0.09,0.01:0.63,0.13,0:0.63,0.16,0.01:0.63,0.19,0:0.63,0.26,0:0.63,0.38,0:0.63,0.5,0:0.63,0.63,0:0.63,0.83,0:0.63,1,0.01:0.63,1.5,0.01:0.63,3,0.01:0.63,4.05,0.01:0.83,0.06,0.02:0.83,0.08,0.01:0.83,0.09,0.01:0.83,0.13,0:0.83,0.16,0.01:0.83,0.19,0:0.83,0.26,0:0.83,0.38,0:0.83,0.5,0:0.83,0.63,0:0.83,0.83,0:0.83,1,0.01:0.83,1.5,0.01:0.83,3,0.01:0.83,4.05,0.01:1.5,0.06,0.02:1.5,0.08,0.01:1.5,0.09,0.01:1.5,0.13,0:1.5,0.16,0.01:1.5,0.19,0:1.5,0.26,0:1.5,0.38,0:1.5,0.5,0:1.5,0.63,0:1.5,0.83,0:1.5,1,0.01:1.5,1.5,0.01:1.5,3,0.01:1.5,4.05,0.01:3,0.06,0.02:3,0.08,0.01:3,0.09,0.01:3,0.13,0:3,0.16,0.01:3,0.19,0:3,0.26,0:3,0.38,0:3,0.5,0:3,0.63,0:3,0.83,0:3,1,0.01:3,1.5,0.01:3,3,0.01:3,4.05,0.01:5,0.06,0.02:5,0.08,0.01:5,0.09,0.01:5,0.13,0:5,0.16,0.01:5,0.19,0:5,0.26,0:5,0.38,0:5,0.5,0:5,0.63,0:5,0.83,0:5,1,0.01:5,1.5,0.01:5,3,0.01:5,4.05,0.01 \
	np_rmetal2_conn::metal2_conn_cut::s,w:0.06,0.06,0:0.06,0.08,0:0.06,0.09,0:0.06,0.13,0:0.06,0.16,0:0.06,0.19,0:0.06,0.26,0:0.06,0.38,0:0.06,0.5,0:0.06,0.63,0:0.06,0.83,0:0.06,1,0:0.06,1.5,0:0.06,3,0:0.06,4.05,0:0.08,0.06,0:0.08,0.08,0:0.08,0.09,0:0.08,0.13,0:0.08,0.16,0:0.08,0.19,0:0.08,0.26,0:0.08,0.38,0:0.08,0.5,0:0.08,0.63,0:0.08,0.83,0:0.08,1,0:0.08,1.5,0:0.08,3,0:0.08,4.05,0:0.09,0.06,0:0.09,0.08,0:0.09,0.09,0:0.09,0.13,0:0.09,0.16,0:0.09,0.19,0:0.09,0.26,0:0.09,0.38,0:0.09,0.5,0:0.09,0.63,0:0.09,0.83,0:0.09,1,0:0.09,1.5,0:0.09,3,0:0.09,4.05,0:0.13,0.06,0.01:0.13,0.08,0.01:0.13,0.09,0.01:0.13,0.13,0:0.13,0.16,0:0.13,0.19,0:0.13,0.26,0:0.13,0.38,0:0.13,0.5,0:0.13,0.63,0:0.13,0.83,0:0.13,1,0:0.13,1.5,0:0.13,3,0:0.13,4.05,0:0.16,0.06,0.01:0.16,0.08,0.01:0.16,0.09,0.01:0.16,0.13,0:0.16,0.16,0:0.16,0.19,0:0.16,0.26,0:0.16,0.38,0:0.16,0.5,0:0.16,0.63,0:0.16,0.83,0:0.16,1,0:0.16,1.5,0:0.16,3,0:0.16,4.05,0:0.19,0.06,0.01:0.19,0.08,0.01:0.19,0.09,0.01:0.19,0.13,0:0.19,0.16,0:0.19,0.19,0:0.19,0.26,0:0.19,0.38,0:0.19,0.5,0:0.19,0.63,0:0.19,0.83,0:0.19,1,0:0.19,1.5,0:0.19,3,0:0.19,4.05,0:0.26,0.06,0.01:0.26,0.08,0.01:0.26,0.09,0.01:0.26,0.13,0:0.26,0.16,0:0.26,0.19,0:0.26,0.26,0:0.26,0.38,0:0.26,0.5,0:0.26,0.63,0:0.26,0.83,0:0.26,1,0:0.26,1.5,0:0.26,3,0:0.26,4.05,0:0.38,0.06,0.01:0.38,0.08,0.01:0.38,0.09,0.01:0.38,0.13,0:0.38,0.16,0:0.38,0.19,0:0.38,0.26,0:0.38,0.38,0:0.38,0.5,0:0.38,0.63,0:0.38,0.83,0:0.38,1,0:0.38,1.5,0:0.38,3,0:0.38,4.05,0:0.63,0.06,0.01:0.63,0.08,0.01:0.63,0.09,0.01:0.63,0.13,0:0.63,0.16,0:0.63,0.19,0:0.63,0.26,0:0.63,0.38,0:0.63,0.5,0:0.63,0.63,0:0.63,0.83,0:0.63,1,0:0.63,1.5,0:0.63,3,0:0.63,4.05,0:0.83,0.06,0.01:0.83,0.08,0.01:0.83,0.09,0.01:0.83,0.13,0:0.83,0.16,0:0.83,0.19,0:0.83,0.26,0:0.83,0.38,0:0.83,0.5,0:0.83,0.63,0:0.83,0.83,0:0.83,1,0:0.83,1.5,0:0.83,3,0:0.83,4.05,0:1.5,0.06,0.01:1.5,0.08,0.01:1.5,0.09,0.01:1.5,0.13,0:1.5,0.16,0:1.5,0.19,0:1.5,0.26,0:1.5,0.38,0:1.5,0.5,0:1.5,0.63,0:1.5,0.83,0:1.5,1,0:1.5,1.5,0:1.5,3,0:1.5,4.05,0:3,0.06,0.01:3,0.08,0.01:3,0.09,0.01:3,0.13,0:3,0.16,0:3,0.19,0:3,0.26,0:3,0.38,0:3,0.5,0:3,0.63,0:3,0.83,0:3,1,0:3,1.5,0:3,3,0:3,4.05,0:5,0.06,0.01:5,0.08,0.01:5,0.09,0.01:5,0.13,0:5,0.16,0:5,0.19,0:5,0.26,0:5,0.38,0:5,0.5,0:5,0.63,0:5,0.83,0:5,1,0:5,1.5,0:5,3,0:5,4.05,0 \
	- rVia1,2,3,t rcont_ndiff_metal1_conn_ndiff_conn,2,t \
	rcont_pdiff_metal1_conn_pdiff_conn,2,t rcont_poly,1,2,t \
	_nmos1v_MOS_2_mgvia,1,z _pmos1v_MOS_10_mgvia,1,z - L1T0,3,I L2T0,2,I \
	L3T0,1,I
rex took  0.03 user, 0.04 sys, 0.00 elapsed, 17960.0 kbytes
# Form resistive via layers
stamp -V -i2 np_rmetal2_conn rVia1 np_rVia1
stamp took  0.09 user, 0.03 sys, 0.00 elapsed, 270904.0 kbytes
geom -V np_rVia1,p_rVia1 - rVia1,1,i,1
stamp -V -i2 np_rmetal1_conn rcont_poly np_rcont_poly
stamp took  0.08 user, 0.02 sys, 0.00 elapsed, 270888.0 kbytes
geom -V np_rcont_poly,p_rcont_poly - rcont_poly,1,i,1
stamp -V -B -i np_rmetal1_conn cont_ndiff_metal1_conn_ndiff_conn
stamp took  0.08 user, 0.02 sys, 1.00 elapsed, 270888.0 kbytes
/bin/cp -f cont_ndiff_metal1_conn_ndiff_conn rcont_ndiff_metal1_conn_ndiff_conn
stamp -V -B -i np_rmetal1_conn cont_pdiff_metal1_conn_pdiff_conn
stamp took  0.07 user, 0.03 sys, 0.00 elapsed, 270884.0 kbytes
/bin/cp -f cont_pdiff_metal1_conn_pdiff_conn rcont_pdiff_metal1_conn_pdiff_conn
# Combine power non-power
/bin/rm -f ndiff_conn
geom np_rndiff_conn,p_rndiff_conn - ndiff_conn,1,i,1
epick -c -f floatlvsnetsfile ndiff_conn ndiff_conn
/bin/rm -f nwell_conn
geom np_rnwell_conn,p_rnwell_conn - nwell_conn,1,i,1
epick -c -f floatlvsnetsfile nwell_conn nwell_conn
/bin/rm -f pdiff_conn
geom np_rpdiff_conn,p_rpdiff_conn - pdiff_conn,1,i,1
epick -c -f floatlvsnetsfile pdiff_conn pdiff_conn
/bin/rm -f poly_conn
geom np_rpoly_conn,p_rpoly_conn - poly_conn,1,i,1
epick -c -f floatlvsnetsfile poly_conn poly_conn
/bin/rm -f pwell
geom np_rpwell,p_rpwell - pwell,1,i,1
epick -c -f floatlvsnetsfile pwell pwell
# Reconnect MOSFET devices
reconnect -V -n NET -s mwires.res -t _nmos1v_MOS_2.trans:_nmos1v_MOS_2.transr \
	_nmos1v_MOS_2 ndiff_conn,_nmos1v_MOS_2_mgvia,pwell -t \
	_pmos1v_MOS_10.trans:_pmos1v_MOS_10.transr _pmos1v_MOS_10 \
	pdiff_conn,_pmos1v_MOS_10_mgvia,nwell_conn
reconnect took 0.00 user, 0.00 sys, 0.00 elapsed, 11744.0 kbytes
changeTransFileNameAP _nmos1v_MOS_2.trans _nmos1v_MOS_2.transr
changeTransFileNameAP _pmos1v_MOS_10.trans _pmos1v_MOS_10.transr
netprint -max NET > original_maxnetfile
# Form capacitance layers for resistive process layers
geom -V -i p_rpoly_conn,np_rpoly_conn - so_poly_conn,1,n
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 2944.0 kbytes
geom -V p_rpoly_conn,np_rpoly_conn - poly_conn,1,i,1
geom -V -i p_rmetal1_conn,np_rmetal1_conn - so_metal1_conn,1,n
geom -V p_rmetal1_conn,np_rmetal1_conn - metal1_conn,1,i,1
geom -V -i p_rmetal2_conn,np_rmetal2_conn - so_metal2_conn,1,n
geom -V p_rmetal2_conn,np_rmetal2_conn - metal2_conn,1,i,1
# Form capacitance layers for non-resistive process layers
grow -V .001 ndiff_conn mask
grow took  0.00 user, 0.00 sys, 0.00 elapsed, 2276.0 kbytes
geom -V pdiff_conn mask - pdiff_conn,10,i,1
geom -V ndiff_conn,pdiff_conn - Oxide,1,i,1
createEmptyLayer metal11_conn
createEmptyLayer metal10_conn
createEmptyLayer metal9_conn
createEmptyLayer metal8_conn
createEmptyLayer metal7_conn
createEmptyLayer metal6_conn
createEmptyLayer metal5_conn
createEmptyLayer metal4_conn
createEmptyLayer metal3_conn
# Form substrate
geom -V p_rnwell_conn,np_rnwell_conn - nwell_conn,1,i,1
geom -V nwell_conn - FOX,1,i,1
xytoebbox -V -g 46.802 -e metal11_conn,metal10_conn,metal9_conn,metal8_conn,metal7_conn,metal6_conn,metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,nwell_conn xg_FOX
grow -V 0.001 FOX g_FOX
grow took  0.00 user, 0.00 sys, 0.00 elapsed, 2280.0 kbytes
geom -V xg_FOX g_FOX - tmp_FOX,10
epick -V -reo -D ${CAP_GROUND} tmp_FOX pick_FOX
grow -V -m 0.002 pick_FOX g_pick_FOX
stamp -i FOX g_pick_FOX
grow -V -m -0.002 g_pick_FOX pick_FOX
grow took  0.00 user, 0.00 sys, 0.00 elapsed, 2512.0 kbytes
sort edges took  0.00 user, 0.00 sys, 0.00 elapsed, 2604.0 kbytes
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3148.0 kbytes
emerge -V pick_FOX FOX tmp1_FOX
emerge took 0.00 user, 0.00 sys, 0.00 elapsed, 2008.0 kbytes
geom -V tmp1_FOX - FOX,1,i,1
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3056.0 kbytes
/bin/rm -f g_pick_FOX xg_FOX tmp_FOX tmp1_FOX
geom -V FOX Oxide - FOX,10,i,1
# Create sip/sw3d/cn3d capacitance data files
cat <<ENDCAT> sip.cmd
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal1_conn,metal2_conn -er \
	metal3_conn.den -n 0.94 -i 0,0.941 -b \
	metal2_conn,metal1_conn,poly_conn,Oxide,FOX -t \
	metal4_conn,metal5_conn,metal6_conn,metal7_conn,metal8_conn,metal9_conn,metal10_conn,metal11_conn \
	-j 0.06 -Maxw 1.41 -p metal3_conn,key 0,0.94 - metal3_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal2_conn,metal3_conn -er \
	metal4_conn.den -n 0.94 -i 0,0.941 -b \
	metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX -t \
	-j 0.06 -Maxw 1.41 -p metal4_conn,key 0,0.94 - metal4_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal3_conn,metal4_conn -er \
	metal5_conn.den -n 1.57 -i 0,1.571 -b \
	metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-t \
	-j 0.06 -Maxw 1.41 -p metal5_conn,key 0,1.57 - metal5_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal4_conn,metal5_conn -er \
	metal6_conn.den -n 1.57 -i 0,1.571 -b \
	metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-t metal7_conn,metal8_conn,metal9_conn,metal10_conn,metal11_conn -j \
	0.06 -Maxw 1.41 -p metal6_conn,key 0,1.57 - metal6_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal5_conn,metal6_conn -er \
	metal7_conn.den -n 1.57 -i 0,1.571 -b \
	metal6_conn,metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-t metal8_conn,metal9_conn,metal10_conn,metal11_conn -j 0.06 -Maxw \
	1.41 -p metal7_conn,key 0,1.57 - metal7_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal6_conn,metal7_conn -er \
	metal8_conn.den -n 1.57 -i 0,1.571 -b \
	metal7_conn,metal6_conn,metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-t metal9_conn,metal10_conn,metal11_conn -j 0.06 -Maxw 1.41 -p \
	metal8_conn,key 0,1.57 - metal8_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal7_conn,metal8_conn -er \
	metal9_conn.den -n 5.4 -i 0,5.401 -b \
	metal8_conn,metal7_conn,metal6_conn,metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-t metal10_conn,metal11_conn -j 0.36 -Maxw 8.1 -p metal9_conn,key \
	0,5.4 - metal9_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal8_conn,metal9_conn -er \
	metal10_conn.den -n 5.4 -i 0,5.401 -b \
	metal9_conn,metal8_conn,metal7_conn,metal6_conn,metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-t metal11_conn -j 0.36 -Maxw 8.1 -p metal10_conn,key 0,5.4 - \
	metal10_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc metal9_conn,metal10_conn -n 23.4 \
	-i 0,23.401 -b \
	metal10_conn,metal9_conn,metal8_conn,metal7_conn,metal6_conn,metal5_conn,metal4_conn,metal3_conn,metal2_conn,metal1_conn,poly_conn,Oxide,FOX \
	-j 2.7 -Maxw 60.75 -p metal11_conn,key 0,23.4 - metal11_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -cp poly_conn,allGate,Oxide -n 1.35 \
	-i 0,1.351 -b Oxide,FOX -t \
	metal1_conn,metal2_conn,metal3_conn,metal4_conn,metal5_conn,metal6_conn,metal7_conn,metal8_conn,metal9_conn,metal10_conn,metal11_conn \
	-j 0.04 -Maxw 2.025 -p poly_conn,key 0,1.35 - poly_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc poly_conn -er metal1_conn.den -n \
	0.94 -i 0,0.941 -b poly_conn,Oxide,FOX -t \
	-j 0.06 -Maxw 1.41 -p metal1_conn,key 0,0.94 - metal1_conn.sip
sip -V -cgnd ${CAP_GROUND} -s -o -sub 2 -mlc poly_conn,metal1_conn -er \
	metal2_conn.den -n 0.94 -i 0,0.941 -b metal1_conn,poly_conn,Oxide,FOX \
	-t \
	-j 0.06 -Maxw 1.41 -p metal2_conn,key 0,0.94 - metal2_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -b \
	-Maxw 60.75 -p metal10_conn,key,metal11_conn,key 0,23.4,0 - \
	metal10_conn_metal11_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal11_conn -b \
	-Maxw 60.75 -p metal9_conn,key,metal11_conn,key 0,23.4,0 - \
	metal9_conn_metal11_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b \
	-t metal11_conn -Maxw 8.1 -p metal9_conn,key,metal10_conn,key 0,5.4,0 \
	- metal9_conn_metal10_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal10_conn -b \
	-t metal11_conn -Maxw 8.1 -p metal8_conn,key,metal10_conn,key 0,5.4,0 \
	- metal8_conn_metal10_conn.sip
	-t metal10_conn,metal11_conn -Maxw 8.1 -p \
	metal8_conn,key,metal9_conn,key 0,5.4,0 - metal8_conn_metal9_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal9_conn -b \
	metal7_conn,key,metal9_conn,key 0,5.4,0 - metal7_conn_metal9_conn.sip
	-t metal9_conn,metal10_conn,metal11_conn -Maxw 1.41 -p \
	metal7_conn,key,metal8_conn,key 0,1.57,0 - \
	metal7_conn_metal8_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal8_conn -b \
	metal6_conn,key,metal8_conn,key 0,1.57,0 - \
	metal6_conn_metal8_conn.sip
	-t metal8_conn,metal9_conn,metal10_conn,metal11_conn -Maxw 1.41 -p \
	metal6_conn,key,metal7_conn,key 0,1.57,0 - \
	metal6_conn_metal7_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal7_conn -b \
	metal5_conn,key,metal7_conn,key 0,1.57,0 - \
	metal5_conn_metal7_conn.sip
	-t metal7_conn,metal8_conn,metal9_conn,metal10_conn,metal11_conn \
	-Maxw 1.41 -p metal5_conn,key,metal6_conn,key 0,1.57,0 - \
	metal5_conn_metal6_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal6_conn -b \
	metal7_conn,metal8_conn,metal9_conn,metal10_conn,metal11_conn -Maxw \
	1.41 -p metal4_conn,key,metal6_conn,key 0,1.57,0 - \
	metal4_conn_metal6_conn.sip
	-Maxw 1.41 -p metal4_conn,key,metal5_conn,key 0,1.57,0 - \
	metal4_conn_metal5_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal5_conn -b \
	-Maxw 1.41 -p metal3_conn,key,metal5_conn,key 0,1.57,0 - \
	metal3_conn_metal5_conn.sip
	-Maxw 1.41 -p metal3_conn,key,metal4_conn,key 0,0.94,0 - \
	metal3_conn_metal4_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal4_conn -b \
	-Maxw 1.41 -p metal2_conn:metal2_conn_cut,key,metal4_conn,key \
	0,0.94,0 - metal2_conn_metal4_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b metal1_conn,poly_conn,Oxide,FOX -t \
	-Maxw 1.41 -p metal2_conn:metal2_conn_cut,key,metal3_conn,key \
	0,0.94,0 - metal2_conn_metal3_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal3_conn -b \
	-k metal2_conn:0.15 -Maxw 1.41 -p \
	metal1_conn:metal1_conn_cut,key,metal3_conn,key 0,0.94,0 - \
	metal1_conn_metal3_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -b poly_conn,Oxide,FOX -t \
	-Maxw 1.41 -p \
	metal1_conn:metal1_conn_cut,key,metal2_conn:metal2_conn_cut,key \
	0,0.94,0 - metal1_conn_metal2_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -L3A -h -R metal2_conn -b Oxide,FOX -t \
	-k metal1_conn:0.15 -Maxw 2.025 -p \
	poly_conn:poly_conn_cut,key,metal2_conn:metal2_conn_cut,key 0,1.35,0 \
	- poly_conn_metal2_conn.sip
sip -V -s -cgnd ${CAP_GROUND} -sub 2 -h -R metal1_conn,poly_conn -b Oxide,FOX \
	-t \
	-Maxw 2.025 -p \
	poly_conn:poly_conn_cut,key,metal1_conn:metal1_conn_cut,key 0,1.35,0 \
	- poly_conn_metal1_conn.sip
ENDCAT
# Prepare gate capacitance blocking layers
emerge -V _nmos1v_MOS_2 _pmos1v_MOS_10 allGate
emerge took 0.00 user, 0.00 sys, 0.00 elapsed, 2012.0 kbytes
# Run pax16 to generate capfile
pax16 -V -lee_off -gnd ${CAP_GROUND} -rmselfC -ignore_cf_table -scf sip.cmd \
	-rP \
	np_rpoly_conn.res,np_rmetal1_conn.res,np_rmetal2_conn.res,mwires.res,rVia1.res,rcont_poly.res,rcont_pdiff_metal1_conn_pdiff_conn.res,rcont_ndiff_metal1_conn_ndiff_conn.res \
	-M_perim_off -c \
	/home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical/qrcTechFile -f \
	FOX Oxide poly_conn:poly_conn_cut metal1_conn:metal1_conn_cut \
	metal2_conn:metal2_conn_cut metal3_conn metal4_conn metal5_conn \
	metal6_conn metal7_conn metal8_conn metal9_conn metal10_conn \
	metal11_conn allGate - \
	/home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical/qrcTechFile - - \
	NET - capfile
pax16_rdpaxcmd took  0.08 user, 0.06 sys, 0.00 elapsed, 50180.0 kbytes
pax16 took  0.03 user, 0.05 sys, 0.00 elapsed, 81328.0 kbytes
# Generate netlister data files
# Perform RC reduction
xreduce -V -mergecap -n NET -tech \
	/home/egad/Shared/ELG4137/gpdk045_v_5_0/qrc/typical -d1 -g \
	${CAP_GROUND},1.0 -danglingR -minR 0.001 -rPvia \
	-rP \
	np_rpoly_conn.res,np_rmetal1_conn.res,np_rmetal2_conn.res,mwires.res \
	-minC 1e-17 -minCper 0.1 -cap capfile L1T0 L2T0 L3T0 \
	_nmos1v_MOS_2.transr _pmos1v_MOS_10.transr
INFO (XREDUCE-199107): Total number of resistors is 32
INFO (XREDUCE-199109): minR option removed 0 resistors (0%)
INFO (XREDUCE-199054): Total number of capacitors in capfile is 143
INFO (XREDUCE-199052): mergecap required for 0 (0%) of 42 nets
INFO (XREDUCE-199113): danglingR option removed 0 resistors
INFO (XREDUCE-199065): minC small capacitor decoupling set to 0.1%
INFO (XREDUCE-199066): minC option decoupled 7 capacitors in capfile
INFO (XREDUCE-199067): the number of capacitors decreased by 1 (1%)
INFO (XREDUCE-199108): d1 option renamed 2 nets
INFO (XREDUCE-199054): Total number of capacitors in capfile is 142
xreduce took 0.07 user, 0.11 sys, 0.00 elapsed, 6680.0 kbytes
# Generate HSPICE file
advgen -V -g0 -li -f -n -o HSPICE -TL L1T0,L2T0,L3T0 -nxref \
	/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/NOR3_compact_LVS_run.gnx \
	-dxref \
	/home/egad/Shared/ELG4137/ELG4137_Lib/NOR3_compact/NOR3_compact_LVS/NOR3_compact_LVS_run/NOR3_compact_LVS_run.gdx \
	-sc caps2dversion -m capfile -rPm res.mod np_rpoly_conn.res \
	np_rmetal1_conn.res np_rmetal2_conn.res rVia1.res rcont_poly.res \
	rcont_pdiff_metal1_conn_pdiff_conn.res \
	rcont_ndiff_metal1_conn_ndiff_conn.res -rPm mwires.mod mwires.res -ta \
	lvsmos.mod,_nmos1v_MOS_2.net _nmos1v_MOS_2.transr -ta \
	lvsmos.mod,_pmos1v_MOS_10.net _pmos1v_MOS_10.transr - NET - \
advgen took:  0.00 user, 0.00 sys, 0.00 elapsed, 7752.0 kbytes
INFO (LBRCXM-610): Extraction finished.
INFO (LBRCXM-582): Checking in license of QTS300 20.10
INFO (LBRCXM-702): Run ended: Wed Mar 29 04:27:58 2023
INFO (LBRCXM-805): Run took: 5s elapsed
INFO (LBRCXM-708): *****  Quantus terminated normally  *****
Fullscreen Quantus_Error.txt Download
Inc.
 /CMC/tools/cadence/ASSURA04.16.111-618_lnx86/tools.lnx86/assura/bin/avRCXxref /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/__qrc.rcx_cmd -useRunName
run on 1850-CO7CMC-008 at Tue Mar 28 15:09:03 2023
Reading rsf
INFO (LBRCXM-630): Starting extraction: Tue Mar 28 15:09:04 2023
Forking:  capgen -techdir /home/cbohe083/Shared/ELG4137/gpdk045_v_5_0/qrc/typical -inc /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3.elf -lvs /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3.xcn -p2lvs /home/cbohe083/Shared/ELG4137/gpdk045_v_5_0/qrc/typical/qrcTechFile -reseqn -p poly_conn,allGate,Oxide -canonical_res_caps -length_units meters -exclude_gate_res -cap_ground_layer psubstrate /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3
Techgen -trans results will be written to directory: /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3
rcxspice took  0.05 user, 0.09 sys, 1.00 elapsed, 5164.0 kbytes
Successfully created RCX script '/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/rcx.sh'
   /bin/ksh  /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/rcx.sh
##AGDS_TEXT_LAYERS=
##ASSURA_RUN_DIR=/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS
##ASSURA_RUN_NAME=NOR3_LVS_run_3
##BREAK_WIDTH=
##CAP_GROUND=Vss
##CAP_MODELS=no
##DANGLINGR=N
##DF2=N
##DRACULA_RUN_DIR=
##DRACULA_RUN_NAME=
##EXTRACT=both
##FILTER_SIZE=2.0
##FMAX=
##GROUND_NETS=
##HCCI_DEV_PROP=7
##HCCI_INST_PROP=6
##HCCI_NET_PROP=5
##HCCI_RULE_FILE=
##HCCI_RUN_DIR=
##HCCI_RUN_NAME=
##IMPORT_GLOBALS=Y
##LADDER_NETWORK=N
##LVS_SOURCE=assura
##M_FACTORR=
##M_FACTORW=N
##MACRO_CELL=Y
##MAX_SIGNALS=
##MINC=1e-17
##MINR=0.001
##OUTPUT=/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/rcx.sp
##PEEC=N
##PIPE_ADVGEN=
##PIPE_SPICE2DB=
##POWER_NETS=
##RC_FREQUENCY=
##RCXDIR=/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3
##RCXFS_HIGH=N
##RCXFS_NETS_FILE=
##RCXFS_TYPE=none
##RCXFS_VIA_OFF=N
##REDUCERC=N
##REGION_LIMIT=
##RES_MODELS=no
##RISE_TIME=
##SHOW_DIODES=N
##SKIN_FREQUENCY=
##SPEF=N
##SPEF_UNITS=
##SPLIT_PINS=N
##SUB_NODE_CHAR='#'
##TEMPDIR=/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/rcx_temp
##TEMPERATURE=25.0
##TYPE=full
##VIA_EFFECT_OFF=N
##VIRTUAL_FILL=
##XREF=/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/NOR3_LVS_run_3.gnx,/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/NOR3_LVS_run_3.gdx
##XY_COORDINATES=C,R,D,M,Q,X
CASE_SENSITIVE=TRUE
TEMPDIR=`setTempDir /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3/rcx_temp`
export TEMPDIR
cd /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3
ENDCAT
meters
ENDCAT
QRC=Y
export QRC
ENDCAT
export GOALIE2DIR
vdbToRcx /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS \
	NOR3_LVS_run_3 -unit meters -- -V1 -H satfile -r \
	/home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS/NOR3_LVS_run_3.xcn \
	-xgl -sv
Opening LVS data for NOR3_LVS_run_3 in /home/cbohe083/Shared/ELG4137/ELG4137_Lib/NOR3/NOR3_LVS
Build pins/attributes took 0.1 sec.
create satfile took  0.01 user, 0.04 sys, 0.00 elapsed, 128224.0 kbytes
write edge poly_conn_pintext took  0.00 user, 0.01 sys, 0.00 elapsed, 128268.0 kbytes
write edge metal2_conn_pintext took  0.00 user, 0.00 sys, 0.00 elapsed, 128288.0 kbytes
write edge metal1_conn_pintext took  0.00 user, 0.00 sys, 0.00 elapsed, 128304.0 kbytes
create netmap file took 0.01 user, 0.00 sys, 0.00 elapsed, 128304.0 kbytes
create net file took 0.00 user, 0.00 sys, 0.00 elapsed, 128340.0 kbytes
write edge cont_ndiff took  0.00 user, 0.00 sys, 0.00 elapsed, 128776.0 kbytes
write edge Via1 took  0.00 user, 0.00 sys, 0.00 elapsed, 128976.0 kbytes
write edge cont_pdiff took  0.00 user, 0.01 sys, 0.00 elapsed, 129116.0 kbytes
write edge cont_poly took  0.00 user, 0.00 sys, 0.00 elapsed, 129272.0 kbytes
write edge _pmos1v_MOS_10 took  0.00 user, 0.00 sys, 0.00 elapsed, 129412.0 kbytes
write edge _nmos1v_MOS_2 took  0.00 user, 0.00 sys, 0.00 elapsed, 129560.0 kbytes
write edge pwell took  0.00 user, 0.00 sys, 0.00 elapsed, 129704.0 kbytes
write edge ptap took  0.00 user, 0.00 sys, 0.00 elapsed, 129844.0 kbytes
write edge ntap took  0.00 user, 0.00 sys, 0.00 elapsed, 129984.0 kbytes
write edge ndiff_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 130124.0 kbytes
write edge poly_conn took  0.00 user, 0.01 sys, 0.00 elapsed, 130264.0 kbytes
write edge pdiff_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 130488.0 kbytes
write edge nwell_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 130628.0 kbytes
write edge metal2_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 130768.0 kbytes
write edge metal1_conn took  0.00 user, 0.00 sys, 0.00 elapsed, 130924.0 kbytes
sort edges took  0.03 user, 0.22 sys, 0.00 elapsed, 2100.0 kbytes
sort edges and labels took  0.23 user, 0.52 sys, 2.00 elapsed, 131084.0 kbytes
	Elapsed:     2 seconds.
	CPU:         0.1 seconds
	Memory      32 Meg
export GOALIE2DIR
densitymap took 0.00 user, 0.01 sys, 0.00 elapsed, 2360.0 kbytes
geom took  0.00 user, 0.01 sys, 0.00 elapsed, 3336.0 kbytes
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3336.0 kbytes
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3332.0 kbytes
beginFlattenInputs
export SAVEDIR
flatnet took 0.00 user, 0.02 sys, 0.00 elapsed, 12092.0 kbytes
flattub took  0.00 user, 0.01 sys, 0.00 elapsed, 4848.0 kbytes
flatnet took 0.00 user, 0.02 sys, 0.00 elapsed, 12080.0 kbytes
flattub took  0.00 user, 0.00 sys, 0.00 elapsed, 4868.0 kbytes
flatnet took 0.00 user, 0.01 sys, 0.00 elapsed, 13552.0 kbytes
flattub took  0.00 user, 0.02 sys, 0.00 elapsed, 3456.0 kbytes
endFlattenInputs
CAP_GROUND= 2
export CAP_GROUND
epick took  0.00 user, 0.00 sys, 0.00 elapsed, 2092.0 kbytes
epick took  0.00 user, 0.01 sys, 0.00 elapsed, 2088.0 kbytes
epick took  0.00 user, 0.01 sys, 0.00 elapsed, 2092.0 kbytes
epick took  0.00 user, 0.01 sys, 0.00 elapsed, 2096.0 kbytes
epick took  0.00 user, 0.02 sys, 1.00 elapsed, 2092.0 kbytes
mergevia -V -tech /home/cbohe083/Shared/ELG4137/gpdk045_v_5_0/qrc/typical \
	-cnt np_rVia1 rVia1 - np_rmetal2_conn np_rmetal1_conn
mergevia took 0.00 user, 0.01 sys, 0.00 elapsed, 9364.0 kbytes
	-cnt np_rcont_poly rcont_poly - np_rmetal1_conn np_rpoly_conn
mergevia took 0.00 user, 0.02 sys, 0.00 elapsed, 9368.0 kbytes
connect took  0.00 user, 0.01 sys, 0.00 elapsed, 270552.0 kbytes
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3068.0 kbytes
mergevia -V -i -tech /home/cbohe083/Shared/ELG4137/gpdk045_v_5_0/qrc/typical \
	-cnt tmp_rcont_ndiff_metal1_conn_ndiff_conn \
mergevia took 0.19 user, 0.29 sys, 2.00 elapsed, 9364.0 kbytes
geom took  0.00 user, 0.01 sys, 0.00 elapsed, 3072.0 kbytes
	-cnt tmp_rcont_pdiff_metal1_conn_pdiff_conn \
mergevia took 0.16 user, 0.29 sys, 0.00 elapsed, 9368.0 kbytes
geom took  0.00 user, 0.01 sys, 0.00 elapsed, 3068.0 kbytes
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 3072.0 kbytes
# 1 np_rpoly_conn
# 2 np_rmetal1_conn
# 3 np_rmetal2_conn
rex -V -m -pd -I'#' -l slab -tech \
	/home/cbohe083/Shared/ELG4137/gpdk045_v_5_0/qrc/typical -map \
	p2elayermapfile -wee p2elayermapfile -N NET -Ply np_rpoly_conn -er \
	np_rmetal2_conn,metal2_conn.den:np_rmetal1_conn,metal1_conn.den -rP \
	L3T0,1,I
    ShawnLogan over 3 years ago
    Dear gaddan14,
    I could not help but notice that it appears what may be your account (user egad?) the extraction is for design NOR3_COMPACT  while in the account associated with user cbohe083, the extraction specifies design NOR3. If user cbohe083 attempts to extract the same design as in account egad (NOR3_COMPACT), does the same error appear as with design NOR3?
    Shawn
