  3. Veriloga model of load behaves differently when standalone...
  • Views 8976
Veriloga model of load behaves differently when standalone or instantiated with other circuit
unSkilled
unSkilled over 3 years ago
Virtuoso version IC6.1.8-64b.500.27
Hi all,
I have the following behavioral model of a current load:
// VerilogA for library, icustom, veriloga
`include "constants.vams"
`include "disciplines.vams"
module icustom(iload);
output iload;
electrical iload;
ground gnd;
real _load_current_array[1:20] = '{1u,2u,4u,8u,10u,20u,40u,80u,100u,200u,400u,800u,1m,2m,4m,8m,10m,20m,40m,50m};
real _iload = 0;
genvar i;
analog begin
    @(initial_step) $strobe("module initialized");
    for (i=1; i<=20; i = i+1) begin
        @(timer(500u+i*50u)) begin
            _iload = _load_current_array[i];
            $strobe("current transition at %r", $abstime);
        end
    end
    I(iload,gnd) <+ transition(_iload, 10n, 10n, 10n);
end
endmodule
I created a standalone testbench to check its behavior and it works as expected. Then I instantiated within a real circuit (a the load of an LDO) and the behavior varies, as seen in the plot below:
Some of the transitions occur as expected but other happen at different times or with different rise times. I'm having a hard time understanding why the behavior would change and I don't see any clearly wrong in the model. Any pointers are highly appreciated.
    Andrew Beckett over 3 years ago in reply to unSkilled +1
    unSkilled said: It seems that the issue is simulator related. The results above are from a third party vendor. When I switch to spectre, the module behaves correctly in both cases. Given that this forum…
  • unSkilled
    Given that this forum is for Cadence products, it probably makes more sense to ask this on a forum for that simulator vendor or to that vendor's customer support.
