  3. Display dimming bindkey stops working after ascending or...
  • Subscribers 136
  • Views 8597
Display dimming bindkey stops working after ascending or descending hierarchy
akhmathew
akhmathew over 3 years ago
I have a bindkey setup for display dimming with the following command:
hiGetCurrentWindow()->dimmingOn=!hiGetCurrentWindow()->dimmingOn
The bindkey stops working when I ascend or descend schematic hierarchy. It starts working again after I manually turn on dimming from View -> Display Dimming
Is there a way to make sure the bindkey works even after ascend/descend?
  • knc
    knc over 3 years ago
    Hello, facing similar issue. Is there a way to have the option in the schematic window "View --> Display Dimming" always checked by default whether ascending or descending ?
    thanks
    Andrew Beckett over 3 years ago in reply to knc
    You could do this:
    envSetVal("layout" "dimmingOn" 'boolean hiGetCurrentWindow()->dimmingOn=!hiGetCurrentWindow()->dimmingOn)
    This toggles it for the window, and sets the cdsenv var which will influence what happens when you descend (at least). I think that ascend may always remember the previous value that was displayed (I haven't fully tested this as it's late)
