  3. Pin Creation Issue in Virtuoso Layout
  • Views 10758
POCHAMREDDY
POCHAMREDDY over 3 years ago
When I try to create a pin named "vss2p7<0>" in the Virtuoso Layout view, I see the following error message:
1. "Cannot create a net with name vss2p7<0>.
2. dbCreateNet: Bus net base name in name "vss2p7" matches a scalar net name that already exists
Could someone explain what the problem is and how to solve it?
  • RobMan
    RobMan over 3 years ago
    You already have a net named vss2p7 in the design and this cannot coexist with a bus of the same name.
  • POCHAMREDDY
    POCHAMREDDY over 3 years ago in reply to RobMan
    In the same hierarchy level of layout and schematic, I see neither nets nor pins named as vss2p7.
  • POCHAMREDDY
    POCHAMREDDY over 3 years ago in reply to POCHAMREDDY
    May I know how to verify whether the net with name "vss2p7" exists or not in layout ?
  • RobMan
    RobMan over 3 years ago in reply to POCHAMREDDY
    Enable the Navigator Assistant, select 'Nets'. The net will be listed, you can filter to help locate it. 'RMB -> Select -> All Shapes On Net' can help find the associated objects.
