  3. Viva waveform save to pdf format not correct
  • Views 7829
chenbobupt
chenbobupt over 3 years ago
When I try to save the waveform to pdf file in ViVa using save image button, the grid on the waveform is not correctly display. There is no horizontal grid and only vertical one. I have to change the size of the picture to very large number to get the horizontal grid but at that moment the font will be very small in the picture. What is controlling the grid display in the output pdf file?
    Which IC sub-version are you using (Help->About will tell you this), and can you share an example which shows the problem? It's hard to know what you mean (perhaps show the cases with the missing grid and with the small fonts).
