  3. Sorting list of version numbers
  • Views 8790
MorrisDH
MorrisDH over 3 years ago
Have a list of version numbers. Example list("v-0.1" "v-1.0" "v-1.1" "v-2.0" "v-11.0" "v-11.2" "v-11.10")
The example is a sorted list and the latest is "v-11.10". The lastest is determined primarily by the number before the dot and secondarily by the number after the dot.
Suppose this list was not sorted? For example, given list("v-1.1" "v-1.0" "v-0.1" "v-11.10" "v-11.0" "v-11.2" "v-2.0") how can I sort this to get the version numbers in order?
    You can use this function:
    ; put in a file with a .ils suffix since this uses local functions
    procedure(CCFsortVersions(versionList)
      let(((versionPat pcreCompile("^v-(\\d+)\\.(\\d+)")))
        procedure(parseVersion(versionNum)
          letseq((
            (match pcreExecute(versionPat versionNum))
            (major match && atoi(pcreSubstitute(versionPat "\\1")) || 0)
            (minor match && atoi(pcreSubstitute(versionPat "\\2")) || 0)
            list(major minor)
        procedure(compare(versionA versionB)
          destructuringBind((majorA minorA) parseVersion(versionA)
            destructuringBind((majorB minorB) parseVersion(versionB)
              if(majorA==majorB then minorA<minorB else majorA<majorB)
        sort(versionList compare)
    This uses regular expressions to parse the version numbers, and then compares using the major versions, falling back to the minor numbers as a tie-breaker.
  • MorrisDH
    MorrisDH over 3 years ago in reply to Andrew Beckett
    Works like a charm.  That code is way over my head. But that's OK for now.
  • MorrisDH
    I found cases where the "string" portion of the version list (the 'v' in my example) can vary.
    Changed the script to take the string part as an additional argument, CCFsortVersions(versionList model). Then changed the pcreCompile to pcreCompile(strcat("^" model "-(\\d+)\\.(\\d+)"))
    It seems to work.
    Then I found another curve ball in some version lists. Sometimes the string can vary within a list. In this case it's anyone's guess as to which version should be 'latest'. The function still runs and if I change the string argument the output can change.
    Andrew Beckett over 3 years ago in reply to MorrisDH
    You could make the code like this:
      let(((versionPat pcreCompile("^(v|V|ver)-(\\d+)\\.(\\d+)")))
          letseq((
            (major match && atoi(pcreSubstitute(versionPat "\\2")) || 0)
            (minor match && atoi(pcreSubstitute(versionPat "\\3")) || 0)
            list(major minor)
    Note that I added a group of alternatives (v|V|ver) in the pattern, and because there was another grouping I incremented the numbers in the pcreSubstitute lines. That would cope with v-1.2, V-2.3, ver-5.60 etc.
